Home » Eclipse Projects » BIRT » Websphere desn't like BIRT...
Websphere desn't like BIRT... [message #976442] Thu, 08 November 2012 10:35 Go to next message
Joe Kennedy is currently offline Joe Kennedy
I am trying to start a deployment of a project to Websphere and I get the following error trail from running a BIRT Viewer Servlet. (Shortened)
org.eclipse.birt.core.exception.BirtException:error.CannotStartupOSGIPlatform
Here is what I found but it does not help me.
http://www.eclipse.org/forums/index.php/m/727929/
https://bugs.eclipse.org/bugs/show_bug.cgi?id=351052
I have the class loader order in Web Sphere set to "Classes loaded with application class loader first." as in the example in the link below.
http://wiki.eclipse.org/BirtPOJO_Viewer_WebSphere_Deployment
I still get the same set of errors and I'm not sure what else I should be doing.
I know it is a bit hard to ask this without posting code, but would someone have an idea as to what I should look for?
Thanks.
Note:
Using Websphere 7.1, BIRT 3.7, Spring 3.1
Another application on the same WAS server is using the same setup using and Engine and Viewer servlet. Most of properties are set the same way. Could there be an overlap here?
Can't share specific code either...
Re: Websphere desn't like BIRT... [message #976856 is a reply to message #976442] Thu, 08 November 2012 17:34 Go to previous messageGo to next message
Michael Williams is currently offline Michael Williams
In your code, are you setting BIRT_HOME? If so, with the POJO runtime, in 3.7, you don't need this and it will probably actually cause the error you're getting above. Let me know.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: Websphere desn't like BIRT... [message #977711 is a reply to message #976856] Fri, 09 November 2012 09:07 Go to previous message
I am not using that at all. I am using the following servlets in my web.xml file.
org.eclipse.birt.report.servlet.ViewerServlet
org.eclipse.birt.report.servlet.BirtEngineServlet
Previous Topic:How to calculate the number of days betwen two dates?
Next Topic:BIRT and .dll files
Current Time: Tue May 21 02:25:08 EDT 2013
Powered by FUDForum. Page generated in 0.01645 seconds
