Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Dynamic overriding
[Acceleo] Dynamic overriding [message #902931] Tue, 21 August 2012 05:14 Go to next message
Hendrik Reddehase is currently offline Hendrik Reddehase
I want to extend an existing code generator. If I have understood the
framework correctly, I have to use the extension point
"org.eclipse.acceleo.engine.dynamic.templates".
So I created two test projects. The first one named
org.eclipse.acceleo.module.sample1 with the following module:
[module M1('http://www.eclipse.org/uml2/2.1.0/UML')]
[template public foo(aClass : Class)]
[bar(aClass)/]
[/template]
[template public bar(aClass : Class)]
M1
[/template]
And a second one named org.eclipse.acceleo.module.sample2 and the module:
[module M2('http://www.eclipse.org/uml2/2.1.0/UML') extends
org::eclipse::acceleo::module::sample1::common::M1]
[template public generator(aClass : Class)]
[comment @main /]
[file ('test.txt', false, 'Cp1252')]
[subfoo(aClass)/]
[/file]
[/template]
[template public subfoo(aClass : Class) overrides foo]
[super/]
[/template]
[template public bar(aClass : Class) overrides bar]
M2
[/template]
The project sample2 has a dependency to sample1 and defines the
extension point "org.eclipse.acceleo.engine.dynamic.templates".
Templates path: src/org/eclipse/acceleo/module/sample2/common/
Generator id: org.eclipse.acceleo.module.sample1
If I start the generator, the content of test.txt is almost M1. But
sometimes it works correctly and I get M2.
So I copied the module M2 to project sample1 added an extension point
etc. and there it seems to be working correctly.
Is this a bug or what is my mistake?
Configuration:
Eclipse 3.7.2 and Acceleo 3.2.1
Thanks a lot for you help.
Hendrik
Re: [Acceleo] Dynamic overriding [message #904398 is a reply to message #902931] Tue, 28 August 2012 07:25 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent Goubet
Hendrik,
The names of the overriden and overriding templates must match :
    [bar(aClass)/]
[/template]
    M1
[/template]
[template public [b]foo[/b](aClass : Class) overrides foo]
    [super/]
[/template]
    M2
[/template]
Laurent Goubet
Obeo
Re: [Acceleo] Dynamic overriding [message #905439 is a reply to message #904398] Thu, 30 August 2012 07:37 Go to previous messageGo to next message
Hi Laurent,
I have already tried this. The Problem is if I make a clean on both
projects and rebuilt both, it only works for the first time and I get
M2. But the result of regeneration is M1.
Hendrik
Am 28.08.2012 13:25, schrieb Laurent Goubet:
> Hendrik,
> [bar(aClass)/]
> [/template]
> M1
> [/template]
> [template public foo(aClass : Class) overrides foo]
> [super/]
> [/template]
> M2
> [/template]
> Laurent Goubet
> Obeo
Re: [Acceleo] Dynamic overriding [message #905470 is a reply to message #905439] Thu, 30 August 2012 08:42 Go to previous messageGo to next message
HI
You mentioned at the outset that you are extending an existing generator.
Do you have both production and development versions of the models
installed in your workspace? There are many potential hazards associated
with this.
You might want to take copies of the (ASCII) *.emtl files in a 'good'
and a 'bad' state to see what the difference is. You'll probably find
that those produced by the editor have different URIs to those from the
builder.
Ed Willink
On 30/08/2012 12:37, Hendrik Reddehase wrote:
> Hi Laurent,
> Hendrik
>> Hendrik,
>> [bar(aClass)/]
>> [/template]
>> M1
>> [/template]
>> [super/]
>> [/template]
>> M2
>> [/template]
>> Laurent Goubet
>> Obeo
Re: [Acceleo] Dynamic overriding [message #977562 is a reply to message #905470] Fri, 09 November 2012 06:30 Go to previous message
yes I know that there are some problems with the production and
development versions of the model. But it does not work in my little
example too and there are no relations to my model. You can find this
example in the attachment.
I found out that the mechanism works, if I have installed the generator
in the runtime. But it only runs for the first time on development time.
I looked for the dynamic templates extension point and debugged it. It
looks like that it works not correctly because the method
added(IExtension[] extensions) of the class
DynamicTemplatesRegistryListener is not always called.
Is this a bug?
Hendrik Reddehase
Am 30.08.2012 14:42, schrieb Ed Willink:
> HI
> with this.
> builder.
> Regards
> Ed Willink
>> Hi Laurent,
>> Hendrik
>>> Hendrik,
>>> [bar(aClass)/]
>>> [/template]
>>> M1
>>> [/template]
>>> [super/]
>>> [/template]
>>> M2
>>> [/template]
>>> Laurent Goubet
>>> Obeo
Previous Topic:[Acceleo] Problem invoke java service
Next Topic:How to interact with metamodel.ecore and Model.xmi elements in one template
Current Time: Fri May 24 08:32:45 EDT 2013
Powered by FUDForum. Page generated in 0.07312 seconds
