Home » Eclipse Projects » Plugin Development Environment (PDE) » View descriptor not found exception in eclipse PDE
View descriptor not found exception in eclipse PDE [message #941308] Fri, 12 October 2012 07:43 Go to next message
Anbazhagan Jayachandran is currently offline Anbazhagan Jayachandran
How can I debug "View descriptor not found" ? I am sure that the view id passed in addView() (called during the perspective's createInitialLayout() method) is really the view id of the view to which I refer and that view is declared in its plugin. In fact, it works in my workspace but not in the binary despite the very same plugins being present in the binary.
Nevertheless, I get "View descriptor not found" (stack trace attached at end).
can anybody help me please
  • Attachment: attach.txt
    (Size: 3.56KB, Downloaded 37 times)
Re: View descriptor not found exception in eclipse PDE [message #977320 is a reply to message #941308] Fri, 09 November 2012 02:24 Go to previous messageGo to next message
its a java version problem i solved it thax for all
Re: View descriptor not found exception in eclipse PDE [message #986604 is a reply to message #977320] Wed, 21 November 2012 02:52 Go to previous message
Sabir Missing name is currently offline Sabir Missing name
Member
java problem ??? I would like to know how you solved it .
Previous Topic:Prevent archiving rcp application in headless build
Next Topic:Launch Run/Debug Configurations
Current Time: Thu May 23 14:45:40 EDT 2013
Powered by FUDForum. Page generated in 0.01614 seconds
