Home » Modeling » OCL » how to call OCL constraints( generated java source code of model ) from the main code of java(want to validate OCL constraints generated in source code from java code)
| how to call OCL constraints( generated java source code of model ) from the main code of java [message #976833] |
Thu, 08 November 2012 17:07  |
Ekansh Missing name Messages: 3 Registered: November 2012 |
Junior Member |
am using OCL constraints on ecore model and generating code. So the thing is as simple as this I have a class Task having attribute startDate and endDate it has an ocl constraint :- invariant which states startDate < endDate.
I have generated java code for this project and there is a java class :
public class TmsValidator extends EObjectValidator {
//what is diagnosticChain and context in the below method
public boolean validateTask_C2(Task task, DiagnosticChain diagnostics, Map<Object, Object context) {
return validate(TmsPackage.Literals.TASK,
task,
diagnostics,
context,
"http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot",
"C2",
TASK__C2__EEXPRESSION,
Diagnostic.ERROR,
DIAGNOSTIC_SOURCE,
0);
So from my main class, how do I validate my task here . I want to call the OCL constraint to check if startDate(Start Date) is less than endDate(End Date)
// How do I validate my task here . I want to call the
//OCL constraint to check if startDate is less than endDate
// this is what I am doing
Map<Object, Object> context = new HashMap<Object, Object>();
BasicDiagnostic diag = new BasicDiagnostic();
Task t= TmsFactory.eINSTANCE.createTask();
boolean flag =TmsValidator.INSTANCE.validateTask_C2(t, diag, context);
System.out.println(flag);
| Re: how to call OCL constraints( generated java source code of model ) from the main code of java [message #977315 is a reply to message #976833] |
Fri, 09 November 2012 02:15  |
Ed Willink Messages: 3151 Registered: July 2009 |
From the EMF Java
* Validates the object in the given context, optionally producing
diagnostics.
* @param diagnostics a place to accumulate diagnostics; if it's
<code>null</code>, no diagnostics should be produced.
* @param context a place to cache information, if it's
<code>null</code>, no cache is supported.
* @return whether the object is valid.
boolean validate(EObject eObject, DiagnosticChain diagnostics,
Map<Object, Object> context);
In practice the 'context' is pre-initialized by the normal EMF
invocation with usefuil helpers such as a SubstitutionLabelProvider.
Ed Willink
> task,
> diagnostics,
> context,
> "C2",
> Diagnostic.ERROR,
> DIAGNOSTIC_SOURCE,
> 0); }
> endDate(End Date)
> public static void main(String[] args) {
> // How do I validate my task here . I want to call the //OCL
> constraint to check if startDate is less than endDate // this is what
> I am doing
> context);
Current Time: Sat May 18 21:53:25 EDT 2013
Powered by FUDForum. Page generated in 0.01784 seconds
