Home » Eclipse Projects » SWTBot » controlling the lifecyle of the application test run
controlling the lifecyle of the application test run [message #977267] Fri, 09 November 2012 01:26
Ramesh D is currently offline Ramesh D
Does anyone know how we can control the lifecycle of the eclipse application that you are running the tests.
This is very much required for us to run tests with clean environment for each test.
Since there are some memory leaks within the application.
Previous Topic:How to click on popupbar tool of GMF editpart
Next Topic:How to maximize the eclipse runtime using SWTBot?
Current Time: Thu May 23 16:50:22 EDT 2013
Powered by FUDForum. Page generated in 0.09111 seconds
