Home » Eclipse Projects » EGit » Move local git repository
Move local git repository [message #976182] Thu, 08 November 2012 06:28 Go to next message
Christoph Keimel is currently offline Christoph Keimel
Hello
I would like to move a local git repository to a different location. How can I tell EGit that the path to the repository has changed?
Thanks for your help!
Greetings
Christoph
Re: Move local git repository [message #976667 is a reply to message #976182] Thu, 08 November 2012 14:05 Go to previous messageGo to next message
Robin Rosenberg is currently offline Robin Rosenberg
Christoph Keimel skrev 2012-11-08 12.28:
> Hello
If the whole repo is inside one project you should be able to right-click and use Refactor->Move. This
is rarely the case in which case you need to delete the repository, move it using a tool outside
eclipse and re-import projects from the new location.
-- robin
Re: Move local git repository [message #976684 is a reply to message #976667] Thu, 08 November 2012 14:25 Go to previous message
Robin Rosenberg skrev 2012-11-08 20.05:
>> Hello
It's Remove Repository from View in the Git Repositories View. NOT Delete.
-- robin
Previous Topic:Merge tool - repository merge view shows non-conflicting files
Next Topic:Commit/amend not possible
Current Time: Tue May 21 11:41:15 EDT 2013
Powered by FUDForum. Page generated in 0.01519 seconds
