Home » Newcomers » Newcomers » Repository empty while calling UpdateSitePublisher
Repository empty while calling UpdateSitePublisher [message #976527] Thu, 08 November 2012 11:50 Go to next message
Missing name Missing name is currently offline Missing name Missing name
This is my call:
java -jar /home/eclipse-4.2/plugins/org.eclipse.equinox.launcher_*.jar -application org.eclipse.equinox.p2.publisher.UpdateSitePublisher -metadataRepository file:$WORKSPACE/build/buildRepo -artifactRepository file:$WORKSPACE/build/buildRepo -source $WORKSPACE/my_feature -features $WORKSPACE -bundles $WORKSPACE -publishArtifacts
This is the output:
Generating metadata for ..
Generation completed with success [0 seconds].
Finished: SUCCESS
In $WORKSPACE there are all features and plugins, that were created using eclipse (actually this is my workspace, but for the build I remove the .metadata folder). This folder has no "features" / "plugins" folders, as an eclipse workspace also has no such folders. "my_feature" contains the site.xml-file and is also the main feature referenced in the site.xml.
This is, what the call creates:
articats.xml
content.xml
Both contain some default headers and metadata, but no artifacts (count = 0). And there are no "features" and "plugins" folders created.
Does anyone know, why?
Re: Repository empty while calling UpdateSitePublisher [message #986326 is a reply to message #976527] Mon, 19 November 2012 20:58 Go to previous message
ding yi is currently offline ding yi
Hi,i met the same problem.
Try this:Open your Eclipse IDE,make the $WORKSPACE path as a real eclipse workspace (import existing project)。Then exit Eclilpse IDE.And then check the path $WORKSPACE,you will find .metadata 。
Run your command again, it should be OK.
Previous Topic:OSx 10.7.4 +Eclipse
Next Topic:Can Eclipse UI be configured in this way?
Current Time: Sun May 19 05:27:05 EDT 2013
Powered by FUDForum. Page generated in 0.01463 seconds
