The bundles are zipped in the URL and inside they are eclipse.import structure.
So, I would need a combination of a URL and eclipse import reader. Is this a standard pattern I can reuse?
Ah ok, many thanks! this works.
I actually have a similar requirements for xtend and mwe. It's hard to even find an archive location for these. Any ideas?
Cheers Christophe
The application, I work on uses these old versions to export EMF models as HTML. (So M2T).
I also use xtext, but this is unrelated to the need for old xtend, xpand and mwe.
Thanks for your help! rgds Christophe
