Home » Eclipse Projects » EclipseLink » @StoredProcedureParameter direction is deprecated
@StoredProcedureParameter direction is deprecated [message #955058] Tue, 23 October 2012 09:22 Go to next message
Neikius Mising name is currently offline Neikius Mising name
Member
@StoredProcedureParameter( direction= )
The above parameter is now "deprecated". How do I indicate that a certain parameter is OUT_CURSOR then? For now the old way works, but I don't see any other way of doing it. suggestions?
Re: @StoredProcedureParameter direction is deprecated [message #964681 is a reply to message #955058] Tue, 30 October 2012 14:10 Go to previous messageGo to next message
James Sutherland is currently offline James Sutherland
What version do you see this in? It should not be deprecated in 2.4, in the development builds it is deprecated as it is being replace by the mode(), which is defined as part of the JPA 2.1 draft.
James : Wiki : Book : Blog
Re: @StoredProcedureParameter direction is deprecated [message #976443 is a reply to message #955058] Thu, 08 November 2012 10:37 Go to previous message
Member
<properties>
	<eclipselink.version>2.4.0</eclipselink.version>
</properties>
<dependency>
	<groupId>org.eclipse.persistence</groupId>
	<artifactId>eclipselink</artifactId>
	<version>${eclipselink.version}</version>
	<scope>compile</scope>
</dependency>
2.4.0
Previous Topic:ValidationException for enum class
Next Topic:Eclipselink and SQLite
Current Time: Fri May 24 05:32:56 EDT 2013
Powered by FUDForum. Page generated in 0.01756 seconds
