| Re: pull from another remote/branch [message #985824 is a reply to message #977448] |
Fri, 16 November 2012 04:51  |
Stefan Lay Messages: 333 Registered: July 2009 |
Could you describe in more detail which branches are on the central repository? If you have a master branch there and if you cloned from there then a pull will actually pull from that master either if you
- have checked out the master branch
- have created your local branch in the way Christoph describes
I personally do not use pull anymore, I use just fetch and decide afterwards when I want to rebase my local changes.
FUDForum. Page generated in 0.12461 seconds
