Home » Eclipse Projects » Target Management » FTP Error
FTP Error [message #975527] Wed, 07 November 2012 18:34 Go to next message
Stefan Meyer is currently offline Stefan Meyer
I try the FTP Only connector to connec t to my FTP Host. The connection looks good but when i click on
Files -> MY Home
or
Files -> Root
i get everytime
"Operation failed. File system input or output error"
instead the folder structurr on the external server ftp folder
How can i fix this?
Is their any other ftp plugin i can test under ecplipse?
index.php/fa/12224/0/
Re: FTP Error [message #976044 is a reply to message #975527] Thu, 08 November 2012 04:16 Go to previous messageGo to next message
Martin Oberhuber is currently offline Martin Oberhuber
Try Window > Show View > Other... : Console
Switch to the FTP Console, it displays the FTP server interaction.
One possible problem is that your server requires passive mode. This can be configured in the connection wizard, a request is open for making it the default:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=269442
If this is not the problem, please file a bug and paste your FTP log for further investigation:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Target%20Management
Searching http://marketplace.eclipse.org for "ftp" brings up a couple of hits that look promising (eg Net Tools and ProjX). Of course I hope that TM will fit your needs once the issue is resolved, but I'd also like to hear if you find something else that is interesting.
Re: FTP Error [message #976098 is a reply to message #976044] Thu, 08 November 2012 05:05 Go to previous message
is this the log?
220 ProFTPD 1.3.3c Server (ProFTPD) [??.??.??.???]
USER myusername
331 Password required for myusername
PASS ******
230 User myusername logged in
SYST
215 UNIX Type: L8
TYPE I
200 Type set to I
PWD
257 "/" is the current directory
NOOP
200 NOOP command successful
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
CWD /
250 CWD command successful
PORT 192,168,1,40,227,136
USER myusername
USER myusername
PASS ******
PASS ?????????????
SYST
SYST
215 UNIX Type: L8
215 UNIX Type: L8
TYPE I
TYPE I
200 Type set to I
200 Type set to I
PWD
PWD
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
NOOP
CWD /
CWD /
PORT 192,168,1,40,227,138
i try this and passivemode. no difference
index.php/fa/12226/0/
[Updated on: Thu, 08 November 2012 05:07]
Report message to a moderator
Previous Topic:Local and external Folder?
Next Topic:Remote system selection problem
Current Time: Fri May 24 21:38:37 EDT 2013
Powered by FUDForum. Page generated in 0.06192 seconds
