Home » Newcomers » Newcomers » Problem with Photran
Problem with Photran [message #916692] Wed, 19 September 2012 06:21 Go to next message
Ingo mayer is currently offline Ingo mayer
I'm fairly new to Eclipse and Photran. I followed the tutorial on the wiki for the HelloWorld program, which worked perfectly.
Now I'm trying to compile a bigger program with several subroutines and get the following error message:
11:54:54 **** Build of configuration Debug for project Testing ****
make all
'Building file: ../Testing.f77'
'Invoking: GNU Fortran Compiler'
gfortran -funderscoring -O0 -g -Wall -c -fmessage-length=0 -o "Testing.o" "../Testing.f77"
gfortran: warning: ../Testing.f77: linker input file unused because linking not done
'Finished building: ../Testing.f77'
'Building target: Testing'
'Invoking: GNU Fortran Linker'
gfortran -o "Testing" ./Testing.o
gfortran: error: ./Testing.o: No such file or directory
make: *** [Testing] Error 1
11:54:55 Build Finished (took 302ms)
Re: Problem with Photran [message #976050 is a reply to message #916692] Thu, 08 November 2012 04:20 Go to previous message
Romana Antczak is currently offline Romana Antczak
Dear Ingo,
according to your message I have a question. Do you already solved this problem? I'm asking because I have the same error and don't know how to solve it. Any idea ?
Previous Topic:Non-persistent way to "Open With -> System Editor"?
Next Topic:Local Client Problem
Current Time: Sat May 18 23:28:28 EDT 2013
Powered by FUDForum. Page generated in 0.04700 seconds
