| Page Size ignored when exporting to PDF [message #975569] |
Wed, 07 November 2012 19:28  |
j k Messages: 428 Registered: September 2012 |
Eclipse Platform
Version: 3.4.2
Build id: M20090211-1700
I have a simple master page in my library
I add it to my report
I then go to modify the added master page at the 'report' level. I set the master page size to custom and increase the width
A warning shows up to indicate that my master page is now different to the one in the library (all good so far) "NOTE: This report item from the library has been modified. To restore the original library item, click on "Restore Properties""
However when I render to PDF the page width change isn't reflected. It's still the same as the size of the master page in the library
If i make a cosmetic change to the master page (in the report, not in the library), like add some text to the header like 'custom' then that shows up when rendering, so some changes are being picked up. But page size changes arent.
Is there a workaround? Am i doing something wrong? or is this a bug?
Will i need to recreate my original master page with the custom size?
FUDForum. Page generated in 0.01854 seconds
