| Error executin tag handler [message #8567] |
Sat, 31 March 2007 16:58  |
Originally posted by: dmachak.xxxx.com
I'm getting the following error while trying to run the default
tranformation in a new EMFT Jet Transformation project:
templates/dump.jet(3,1): <c:dump entities="true" format="true"
select="/*">
Error: Error executing tag handler: java.lang.NullPointerException
I'm running Eclipse 3.2.1, with EMF 2.3.0 and JET 0.7.100.
All I'm doing is selecting sample.xml and selecting Run As... input for
JET transformation.
Is there something I'm doing wrong, or is this a problem with my
combination of versions?
Thanks for any help you can give.
Dan
FUDForum. Page generated in 0.02125 seconds
