Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » Visualizing Android .trace file by convert it to TPTP .trcxml file(Converter tool : .trace ---> .trcxml)
Visualizing Android .trace file by convert it to TPTP .trcxml file [message #975056] Wed, 07 November 2012 10:00 Go to next message
Ali Navab is currently offline Ali Navab
Hi All
I profiled my android application by DDMS and i have a .trace file. But traceview.bat tool of android sdk is not good for visualizing the trace file. I find TPTP as a good tracer and Profiler but i can't visualize my .trace file with it. I need to convert android .trace file to .trcxml TPTP readable file.
in "http://live.eclipse.org/node/710", i found a presentation about it but there is no reference for the tool.
any body have any experience about trace file converting for TPTP?
Re: Visualizing Android .trace file by convert it to TPTP .trcxml file [message #976345 is a reply to message #975056] Thu, 08 November 2012 09:06 Go to previous message
Torsten Stolpmann is currently offline Torsten Stolpmann
Member
From what I found this converter has never been released but it may help to contact the original authors about it to shed some light on it.
If you plan to reimplement this, there is an XML schema available for the TPTP trace file format and you may build example files as described here: http://www.eclipse.org/forums/index.php/t/152436/
Hope this helps,
Torsten
See also: http://www.eclipse.org/tptp/platform/documents/resources/profilingspec/XML4Profiling.htm
[Updated on: Thu, 08 November 2012 09:15]
Report message to a moderator
Previous Topic:What do you think about Q7 UI testing tool?
Next Topic:While trying to profile an ear application
Current Time: Sun May 19 01:13:26 EDT 2013
Powered by FUDForum. Page generated in 0.02088 seconds
