Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Texo on Indigo Windows 32 bit(Install Texo on Indigo Eclipse package)
Texo on Indigo Windows 32 bit [message #974591] Wed, 07 November 2012 02:06 Go to next message
Pradeep Badiger is currently offline Pradeep Badiger
Member
Is it possible to install Texo plugin on Eclipse Indigo package (Windows 32 bit)?
If yes, what are the steps to install? Any texo update url?
thanks,
Pradeep V.B.
Re: Texo on Indigo Windows 32 bit [message #974653 is a reply to message #974591] Wed, 07 November 2012 03:12 Go to previous messageGo to next message
Martin Taal is currently offline Martin Taal
Hi Pradeep,
I noticed that one of the plugin dependencies was too restrictive for Indigo. I changed that and am doing a test build
against Indigo.
gr. Martin
On 11/07/2012 08:06 AM, Pradeep Badiger wrote:
> thanks,
> Pradeep V.B.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: Texo on Indigo Windows 32 bit [message #974702 is a reply to message #974653] Wed, 07 November 2012 04:03 Go to previous messageGo to next message
Member
Hi Martin,
I gave a try again today and saw there was a dependecy on Xtext 2.3, so installed it and then tried installing Texo and you know what, it got installed without any issues.. I am testing out some code generation test cases. Please let me know if you have any update on this as well. so that i dont miss anything..
Thanks for your help.. Smile
regards,
Pradeep V.B.
Re: Texo on Indigo Windows 32 bit [message #974712 is a reply to message #974702] Wed, 07 November 2012 04:05 Go to previous message
Hi Pradeep,
Indeed that was the one dependency. I did a build on Indigo but it failed (because of an older version of xtext) so the
xtend templates really depend on xtext 2.3.
Afaics your approach of using xtext 2.3 in indigo seems to be a fine approach to me!
gr. Martin
On 11/07/2012 10:03 AM, Pradeep Badiger wrote:
> Hi Martin,
> Thanks for your help.. :)
> regards,
> Pradeep V.B.
The Netherlands
Previous Topic:[Texo] My template overrides are not being used
Next Topic:Generate entity annotations in orm file
Current Time: Sat May 18 22:38:41 EDT 2013
Powered by FUDForum. Page generated in 0.04252 seconds
