Home » Newcomers » Newcomers » Installing IBM Worklight throwing error
Installing IBM Worklight throwing error [message #973146] Tue, 06 November 2012 00:24 Go to next message
Manoj R is currently offline Manoj R
I am trying to install IBM Worklight on eclipse,(Help -> Install New Software). After adding the archieve file am getting the error as follows,
Cannot complete the install because one or more required items could not be found.
Software being installed: IBM Worklight Studio 1.0.0.v20120606_0243 (com.ibm.imp.tools.wee.feature.feature.group 1.0.0.v20120606_0243)
Missing requirement: Links Indexer and Database 1.2.0.v20120424_0145 (com.ibm.etools.references 1.2.0.v20120424_0145) requires 'bundle org.eclipse.core.filesystem [1.3.1,4.0.0)' but it could not be found
Cannot satisfy dependency:
From: The Web References framework 1.2.0.v20120518_1925 (com.ibm.etools.references.feature.feature.group 1.2.0.v20120518_1925)
To: com.ibm.etools.references [1.2.0.v20120424_0145]
From: IBM Worklight Studio 1.0.0.v20120606_0243 (com.ibm.imp.tools.wee.feature.feature.group 1.0.0.v20120606_0243)
To: com.ibm.etools.references.feature.feature.group 1.2.0
My OS is RedHat Linux and I am having java 6 installed in the system, and tried with Eclipse Helios,Juno,Indigo and version 3.8, but getting the same error.
Any suggesstions please.
Re: Installing IBM Worklight throwing error [message #973979 is a reply to message #973146] Tue, 06 November 2012 14:24 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
> be found.
> the same error.
org.eclipse.core.filesystem seems to be at the root of your problems,
and it was included in Helios SR2. In case there's any confusion, you
should be using Helios SR2, Indigo SR2, or Juno SR1. The original
releases themselves are not supported by Worklight Studio.
The Worklight forum at
http://www.ibm.com/developerworks/forums/forum.jspa?forumID=2830 is
probably a better place to follow up.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Re: Installing IBM Worklight throwing error [message #974487 is a reply to message #973979] Wed, 07 November 2012 00:09 Go to previous message
I have downloaded Eclispe Helios SR2(3.6.2) version and tried to install Worklight plugin. But am getting the same error.
Kindly clarify and tell which eclipse version is compatible to install Worklight studio Enterprise edition.
Previous Topic:to print sum of elements of a column in the row area of a crosstab in BIRT
Next Topic:Problem Starting Eclipse
Current Time: Sat May 25 21:25:48 EDT 2013
Powered by FUDForum. Page generated in 0.01524 seconds
