Home » Eclipse Projects » EclipseLink » EntityManagerFactory (Eclipselink RCP) return NullPointerException
| Re: EntityManagerFactory (Eclipselink RCP) return NullPointerException [message #965764 is a reply to message #964494] |
Wed, 31 October 2012 09:41   |
Azi Azwady Jamaludin Messages: 10 Registered: October 2012 |
Junior Member |
Hi Shaun,
I've just tried Gemini JPA. Also changing the MamsysEntityManagerFactory properties as attach but the result still the same.
!STACK 0
at org.eclipse.mamsysdispose.model.connection.MamsysEntityManagerFactory.createEntityManager(MamsysEntityManagerFactory.java:52)
at org.eclipse.mamsysdispose.model.CreateCaseModel.<init>(CreateCaseModel.java:24)
at org.eclipse.mamsysdispose.views.viewparts.NewCaseView$2$1.run(NewCaseView.java:162)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Also put the driver (mysql-connector-java-5.1.22-bin.jar) in Bundle-Classpath. (JPA Project that been converted into Plug-in project)
Something is missing I quest
[Updated on: Wed, 31 October 2012 12:09] Report message to a moderator
Re: EntityManagerFactory (Eclipselink RCP) return NullPointerException [message #972764 is a reply to message #972284] |
Mon, 05 November 2012 17:06   |
Junior Member |
Hi Shaun,
I think there is a connection but i'm sure something needs to be configured. I attach all the stack trace here:
Hello World!!
[EL Config]: metadata: 2012-11-06 05:42:12.781--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.MainList] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.811--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field process] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Process.
[EL Config]: metadata: 2012-11-06 05:42:12.812--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field initialReceive] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:12.813--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field createCase] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.CreateCase.
[EL Config]: metadata: 2012-11-06 05:42:12.813--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field postapprDoc] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:12.813--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.PostapprQuery] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.815--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field postapprDoc] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:12.873--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field postapprDocs] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:12.889--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.AppliQuery] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.889--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field initialReceive] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:12.89--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field initialReceives] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:12.89--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.CreateCase] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.891--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:12.892--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field registerUser] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.RegisterUser.
[EL Config]: metadata: 2012-11-06 05:42:12.892--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.Process] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.893--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:12.893--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field kewPa17] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.894--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field approQueries] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.ApproQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.894--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.ApproQuery] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.894--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.895--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field process] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Process.
[EL Config]: metadata: 2012-11-06 05:42:12.895--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.PostapprDoc] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.896--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:12.896--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field postapprQuery] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.897--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field postapprQueries] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.897--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.Approval] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.897--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.899--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.KewPA17] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.899--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field processes] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Process.
[EL Config]: metadata: 2012-11-06 05:42:12.899--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field approval] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Approval.
[EL Config]: metadata: 2012-11-06 05:42:12.9--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field approQuery] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.ApproQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.9--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field kewPa172] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:12.901--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field kewPa173] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:12.901--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.RegisterUser] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.902--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field createCases] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.CreateCase.
[EL Config]: metadata: 2012-11-06 05:42:12.902--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.InitialReceive] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.903--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:12.903--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field appliQuery] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.AppliQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.907--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field appliQueries] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.AppliQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.915--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.KewPA17_2] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.917--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.918--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.KewPA17_3] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.918--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.919--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.MainListPK] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.944--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.MainList] is being defaulted to: MainList.
[EL Config]: metadata: 2012-11-06 05:42:12.946--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.MainList] is being defaulted to: MAINLIST.
[EL Config]: metadata: 2012-11-06 05:42:12.966--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [postapprDoc_idfinalDoc] is being defaulted to: POSTAPPRDOC_IDFINALDOC.
[EL Config]: metadata: 2012-11-06 05:42:12.967--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [createCase_idcaseID] is being defaulted to: CREATECASE_IDCASEID.
[EL Config]: metadata: 2012-11-06 05:42:12.967--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [initialReceive_idinitialReceive] is being defaulted to: INITIALRECEIVE_IDINITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:12.971--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.PostapprQuery] is being defaulted to: PostapprQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.972--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.PostapprQuery] is being defaulted to: POSTAPPRQUERY.
[EL Config]: metadata: 2012-11-06 05:42:12.972--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [finalQuery_Letterdate] is being defaulted to: FINALQUERY_LETTERDATE.
[EL Config]: metadata: 2012-11-06 05:42:12.975--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [finalQuery_ref] is being defaulted to: FINALQUERY_REF.
[EL Config]: metadata: 2012-11-06 05:42:12.975--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idfinalQuery] is being defaulted to: IDFINALQUERY.
[EL Config]: metadata: 2012-11-06 05:42:12.976--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:12.976--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.AppliQuery] is being defaulted to: AppliQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.977--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.AppliQuery] is being defaulted to: APPLIQUERY.
[EL Config]: metadata: 2012-11-06 05:42:12.977--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [appliQuery_ref] is being defaulted to: APPLIQUERY_REF.
[EL Config]: metadata: 2012-11-06 05:42:12.977--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idappliQuery] is being defaulted to: IDAPPLIQUERY.
[EL Config]: metadata: 2012-11-06 05:42:12.977--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:12.978--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [appliQuery_Letterdate] is being defaulted to: APPLIQUERY_LETTERDATE.
[EL Config]: metadata: 2012-11-06 05:42:12.978--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.CreateCase] is being defaulted to: CreateCase.
[EL Config]: metadata: 2012-11-06 05:42:12.978--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.CreateCase] is being defaulted to: CREATECASE.
[EL Config]: metadata: 2012-11-06 05:42:12.978--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idcaseID] is being defaulted to: IDCASEID.
[EL Config]: metadata: 2012-11-06 05:42:12.978--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [logdate] is being defaulted to: LOGDATE.
[EL Config]: metadata: 2012-11-06 05:42:12.979--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [officeLocation] is being defaulted to: OFFICELOCATION.
[EL Config]: metadata: 2012-11-06 05:42:12.979--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:12.979--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [department] is being defaulted to: DEPARTMENT.
[EL Config]: metadata: 2012-11-06 05:42:12.979--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:12.98--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [state] is being defaulted to: STATE.
[EL Config]: metadata: 2012-11-06 05:42:12.98--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.Process] is being defaulted to: Process.
[EL Config]: metadata: 2012-11-06 05:42:12.98--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.Process] is being defaulted to: PROCESS.
[EL Config]: metadata: 2012-11-06 05:42:12.98--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idprocess] is being defaulted to: IDPROCESS.
[EL Config]: metadata: 2012-11-06 05:42:12.981--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:12.981--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:12.981--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [processReceive_date] is being defaulted to: PROCESSRECEIVE_DATE.
[EL Config]: metadata: 2012-11-06 05:42:12.981--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [processLetter_date] is being defaulted to: PROCESSLETTER_DATE.
[EL Config]: metadata: 2012-11-06 05:42:12.981--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [processLetter_ref] is being defaulted to: PROCESSLETTER_REF.
[EL Config]: metadata: 2012-11-06 05:42:12.982--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.ApproQuery] is being defaulted to: ApproQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.982--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.ApproQuery] is being defaulted to: APPROQUERY.
[EL Config]: metadata: 2012-11-06 05:42:12.982--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [approQuery_Letterdate] is being defaulted to: APPROQUERY_LETTERDATE.
[EL Config]: metadata: 2012-11-06 05:42:12.982--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [approQuery_ref] is being defaulted to: APPROQUERY_REF.
[EL Config]: metadata: 2012-11-06 05:42:12.983--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idapproQuery] is being defaulted to: IDAPPROQUERY.
[EL Config]: metadata: 2012-11-06 05:42:12.983--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:12.983--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.PostapprDoc] is being defaulted to: PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:12.983--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.PostapprDoc] is being defaulted to: POSTAPPRDOC.
[EL Config]: metadata: 2012-11-06 05:42:12.983--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idfinalDoc] is being defaulted to: IDFINALDOC.
[EL Config]: metadata: 2012-11-06 05:42:12.984--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [finaldocLetter_ref] is being defaulted to: FINALDOCLETTER_REF.
[EL Config]: metadata: 2012-11-06 05:42:12.984--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [finaldocReceive_date] is being defaulted to: FINALDOCRECEIVE_DATE.
[EL Config]: metadata: 2012-11-06 05:42:12.984--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:12.984--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:12.984--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [finaldocLetter_date] is being defaulted to: FINALDOCLETTER_DATE.
[EL Config]: metadata: 2012-11-06 05:42:12.985--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [kewPA19] is being defaulted to: KEWPA19.
[EL Config]: metadata: 2012-11-06 05:42:12.985--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [kewPA18] is being defaulted to: KEWPA18.
[EL Config]: metadata: 2012-11-06 05:42:12.985--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.Approval] is being defaulted to: Approval.
[EL Config]: metadata: 2012-11-06 05:42:12.988--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.Approval] is being defaulted to: APPROVAL.
[EL Config]: metadata: 2012-11-06 05:42:12.989--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [letterdate_toDept] is being defaulted to: LETTERDATE_TODEPT.
[EL Config]: metadata: 2012-11-06 05:42:12.989--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [letterdate_toTry] is being defaulted to: LETTERDATE_TOTRY.
[EL Config]: metadata: 2012-11-06 05:42:12.989--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [refappr_toDept] is being defaulted to: REFAPPR_TODEPT.
[EL Config]: metadata: 2012-11-06 05:42:12.989--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [month_Appr] is being defaulted to: MONTH_APPR.
[EL Config]: metadata: 2012-11-06 05:42:12.99--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [refletter_toTry] is being defaulted to: REFLETTER_TOTRY.
[EL Config]: metadata: 2012-11-06 05:42:12.99--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idapproval] is being defaulted to: IDAPPROVAL.
[EL Config]: metadata: 2012-11-06 05:42:12.99--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [year_Appr] is being defaulted to: YEAR_APPR.
[EL Config]: metadata: 2012-11-06 05:42:12.99--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [letterdate_Tryappr] is being defaulted to: LETTERDATE_TRYAPPR.
[EL Config]: metadata: 2012-11-06 05:42:12.99--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [refappr_frTry] is being defaulted to: REFAPPR_FRTRY.
[EL Config]: metadata: 2012-11-06 05:42:12.991--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.KewPA17] is being defaulted to: KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.991--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.KewPA17] is being defaulted to: KEWPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.991--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:12.991--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idkewPA17] is being defaulted to: IDKEWPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.992--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [deptshName] is being defaulted to: DEPTSHNAME.
[EL Config]: metadata: 2012-11-06 05:42:12.992--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:12.992--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.RegisterUser] is being defaulted to: RegisterUser.
[EL Config]: metadata: 2012-11-06 05:42:12.992--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.RegisterUser] is being defaulted to: REGISTERUSER.
[EL Config]: metadata: 2012-11-06 05:42:12.993--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:12.993--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idregisterUser] is being defaulted to: IDREGISTERUSER.
[EL Config]: metadata: 2012-11-06 05:42:12.993--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [password] is being defaulted to: PASSWORD.
[EL Config]: metadata: 2012-11-06 05:42:12.993--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.InitialReceive] is being defaulted to: InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:12.994--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.InitialReceive] is being defaulted to: INITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:12.994--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [initialReceive_date] is being defaulted to: INITIALRECEIVE_DATE.
[EL Config]: metadata: 2012-11-06 05:42:12.994--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idinitialReceive] is being defaulted to: IDINITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:12.995--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [initialLetter_date] is being defaulted to: INITIALLETTER_DATE.
[EL Config]: metadata: 2012-11-06 05:42:12.995--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:12.995--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [dateTo_inspect] is being defaulted to: DATETO_INSPECT.
[EL Config]: metadata: 2012-11-06 05:42:12.995--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:12.996--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [initialLetter_ref] is being defaulted to: INITIALLETTER_REF.
[EL Config]: metadata: 2012-11-06 05:42:12.996--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.KewPA17_2] is being defaulted to: KewPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:12.996--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.KewPA17_2] is being defaulted to: KEWPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:12.996--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idkewPA17_2] is being defaulted to: IDKEWPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:12.997--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.KewPA17_3] is being defaulted to: KewPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:12.997--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.KewPA17_3] is being defaulted to: KEWPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:12.997--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idkewPA17_3] is being defaulted to: IDKEWPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:13.053--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field process] is being defaulted to: IDPROCESS.
[EL Config]: metadata: 2012-11-06 05:42:13.054--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [process] is being defaulted to: PROCESS_IDPROCESS.
[EL Config]: metadata: 2012-11-06 05:42:13.054--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field initialReceive] is being defaulted to: IDINITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:13.054--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [initialReceive] is being defaulted to: INITIALRECEIVE_IDINITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:13.055--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field createCase] is being defaulted to: IDCASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.055--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [createCase] is being defaulted to: CREATECASE_IDCASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.055--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field postapprDoc] is being defaulted to: IDFINALDOC.
[EL Config]: metadata: 2012-11-06 05:42:13.055--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [postapprDoc] is being defaulted to: POSTAPPRDOC_IDFINALDOC.
[EL Config]: metadata: 2012-11-06 05:42:13.056--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field postapprDoc] is being defaulted to: IDFINALDOC.
[EL Config]: metadata: 2012-11-06 05:42:13.056--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field initialReceive] is being defaulted to: IDINITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:13.056--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field registerUser] is being defaulted to: IDREGISTERUSER.
[EL Config]: metadata: 2012-11-06 05:42:13.056--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field kewPa17] is being defaulted to: IDKEWPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.061--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [kewPa17] is being defaulted to: KEWPA17_IDKEWPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.061--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field process] is being defaulted to: IDPROCESS.
[EL Config]: metadata: 2012-11-06 05:42:13.062--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field postapprQuery] is being defaulted to: IDFINALQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.062--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [postapprQuery] is being defaulted to: POSTAPPRQUERY_IDFINALQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.062--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field approQuery] is being defaulted to: IDAPPROQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.062--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [approQuery] is being defaulted to: APPROQUERY_IDAPPROQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.063--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field approval] is being defaulted to: IDAPPROVAL.
[EL Config]: metadata: 2012-11-06 05:42:13.063--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field kewPa172] is being defaulted to: IDKEWPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:13.064--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field kewPa173] is being defaulted to: IDKEWPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:13.064--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field appliQuery] is being defaulted to: IDAPPLIQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.064--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [appliQuery] is being defaulted to: APPLIQUERY_IDAPPLIQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.098--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.MainList] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.098--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field process] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Process.
[EL Config]: metadata: 2012-11-06 05:42:13.099--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field initialReceive] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:13.099--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field createCase] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.CreateCase.
[EL Config]: metadata: 2012-11-06 05:42:13.099--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field postapprDoc] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:13.099--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.PostapprQuery] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.1--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field postapprDoc] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:13.103--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field postapprDocs] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:13.103--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.AppliQuery] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.104--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field initialReceive] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:13.104--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field initialReceives] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:13.105--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.CreateCase] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.105--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:13.11--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field registerUser] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.RegisterUser.
[EL Config]: metadata: 2012-11-06 05:42:13.11--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.Process] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.111--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:13.111--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field kewPa17] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.111--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field approQueries] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.ApproQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.112--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.ApproQuery] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.112--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.112--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field process] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Process.
[EL Config]: metadata: 2012-11-06 05:42:13.112--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.PostapprDoc] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.113--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:13.113--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field postapprQuery] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.113--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field postapprQueries] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.114--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.Approval] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.114--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.115--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.KewPA17] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.115--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field processes] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Process.
[EL Config]: metadata: 2012-11-06 05:42:13.115--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field approval] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Approval.
[EL Config]: metadata: 2012-11-06 05:42:13.116--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field approQuery] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.ApproQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.116--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field kewPa172] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:13.116--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field kewPa173] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:13.117--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.RegisterUser] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.117--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field createCases] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.CreateCase.
[EL Config]: metadata: 2012-11-06 05:42:13.118--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.InitialReceive] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.118--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:13.118--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field appliQuery] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.AppliQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.12--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field appliQueries] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.AppliQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.12--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.KewPA17_2] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.12--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.121--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.KewPA17_3] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.121--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.122--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.MainListPK] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.122--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.MainList] is being defaulted to: MainList.
[EL Config]: metadata: 2012-11-06 05:42:13.122--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.MainList] is being defaulted to: MAINLIST.
[EL Config]: metadata: 2012-11-06 05:42:13.127--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [postapprDoc_idfinalDoc] is being defaulted to: POSTAPPRDOC_IDFINALDOC.
[EL Config]: metadata: 2012-11-06 05:42:13.127--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [createCase_idcaseID] is being defaulted to: CREATECASE_IDCASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.127--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [initialReceive_idinitialReceive] is being defaulted to: INITIALRECEIVE_IDINITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:13.127--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.PostapprQuery] is being defaulted to: PostapprQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.128--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.PostapprQuery] is being defaulted to: POSTAPPRQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.128--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [finalQuery_Letterdate] is being defaulted to: FINALQUERY_LETTERDATE.
[EL Config]: metadata: 2012-11-06 05:42:13.128--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [finalQuery_ref] is being defaulted to: FINALQUERY_REF.
[EL Config]: metadata: 2012-11-06 05:42:13.128--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idfinalQuery] is being defaulted to: IDFINALQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.128--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:13.129--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.AppliQuery] is being defaulted to: AppliQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.129--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.AppliQuery] is being defaulted to: APPLIQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.129--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [appliQuery_ref] is being defaulted to: APPLIQUERY_REF.
[EL Config]: metadata: 2012-11-06 05:42:13.129--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idappliQuery] is being defaulted to: IDAPPLIQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.129--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:13.13--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [appliQuery_Letterdate] is being defaulted to: APPLIQUERY_LETTERDATE.
[EL Config]: metadata: 2012-11-06 05:42:13.13--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.CreateCase] is being defaulted to: CreateCase.
[EL Config]: metadata: 2012-11-06 05:42:13.13--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.CreateCase] is being defaulted to: CREATECASE.
[EL Config]: metadata: 2012-11-06 05:42:13.13--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idcaseID] is being defaulted to: IDCASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.13--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [logdate] is being defaulted to: LOGDATE.
[EL Config]: metadata: 2012-11-06 05:42:13.13--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [officeLocation] is being defaulted to: OFFICELOCATION.
[EL Config]: metadata: 2012-11-06 05:42:13.131--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:13.131--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [department] is being defaulted to: DEPARTMENT.
[EL Config]: metadata: 2012-11-06 05:42:13.131--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.131--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [state] is being defaulted to: STATE.
[EL Config]: metadata: 2012-11-06 05:42:13.131--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.Process] is being defaulted to: Process.
[EL Config]: metadata: 2012-11-06 05:42:13.132--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.Process] is being defaulted to: PROCESS.
[EL Config]: metadata: 2012-11-06 05:42:13.132--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idprocess] is being defaulted to: IDPROCESS.
[EL Config]: metadata: 2012-11-06 05:42:13.132--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:13.132--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.132--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [processReceive_date] is being defaulted to: PROCESSRECEIVE_DATE.
[EL Config]: metadata: 2012-11-06 05:42:13.133--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [processLetter_date] is being defaulted to: PROCESSLETTER_DATE.
[EL Config]: metadata: 2012-11-06 05:42:13.133--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [processLetter_ref] is being defaulted to: PROCESSLETTER_REF.
[EL Config]: metadata: 2012-11-06 05:42:13.133--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.ApproQuery] is being defaulted to: ApproQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.133--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.ApproQuery] is being defaulted to: APPROQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.133--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [approQuery_Letterdate] is being defaulted to: APPROQUERY_LETTERDATE.
[EL Config]: metadata: 2012-11-06 05:42:13.134--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [approQuery_ref] is being defaulted to: APPROQUERY_REF.
[EL Config]: metadata: 2012-11-06 05:42:13.134--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idapproQuery] is being defaulted to: IDAPPROQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.134--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:13.134--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.PostapprDoc] is being defaulted to: PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:13.134--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.PostapprDoc] is being defaulted to: POSTAPPRDOC.
[EL Config]: metadata: 2012-11-06 05:42:13.134--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idfinalDoc] is being defaulted to: IDFINALDOC.
[EL Config]: metadata: 2012-11-06 05:42:13.135--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [finaldocLetter_ref] is being defaulted to: FINALDOCLETTER_REF.
[EL Config]: metadata: 2012-11-06 05:42:13.135--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [finaldocReceive_date] is being defaulted to: FINALDOCRECEIVE_DATE.
[EL Config]: metadata: 2012-11-06 05:42:13.135--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:13.135--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.135--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [finaldocLetter_date] is being defaulted to: FINALDOCLETTER_DATE.
[EL Config]: metadata: 2012-11-06 05:42:13.136--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [kewPA19] is being defaulted to: KEWPA19.
[EL Config]: metadata: 2012-11-06 05:42:13.136--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [kewPA18] is being defaulted to: KEWPA18.
[EL Config]: metadata: 2012-11-06 05:42:13.136--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.Approval] is being defaulted to: Approval.
[EL Config]: metadata: 2012-11-06 05:42:13.136--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.Approval] is being defaulted to: APPROVAL.
[EL Config]: metadata: 2012-11-06 05:42:13.136--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [letterdate_toDept] is being defaulted to: LETTERDATE_TODEPT.
[EL Config]: metadata: 2012-11-06 05:42:13.136--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [letterdate_toTry] is being defaulted to: LETTERDATE_TOTRY.
[EL Config]: metadata: 2012-11-06 05:42:13.137--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [refappr_toDept] is being defaulted to: REFAPPR_TODEPT.
[EL Config]: metadata: 2012-11-06 05:42:13.137--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [month_Appr] is being defaulted to: MONTH_APPR.
[EL Config]: metadata: 2012-11-06 05:42:13.137--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [refletter_toTry] is being defaulted to: REFLETTER_TOTRY.
[EL Config]: metadata: 2012-11-06 05:42:13.137--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idapproval] is being defaulted to: IDAPPROVAL.
[EL Config]: metadata: 2012-11-06 05:42:13.138--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [year_Appr] is being defaulted to: YEAR_APPR.
[EL Config]: metadata: 2012-11-06 05:42:13.138--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [letterdate_Tryappr] is being defaulted to: LETTERDATE_TRYAPPR.
[EL Config]: metadata: 2012-11-06 05:42:13.138--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [refappr_frTry] is being defaulted to: REFAPPR_FRTRY.
[EL Config]: metadata: 2012-11-06 05:42:13.138--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.KewPA17] is being defaulted to: KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.138--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.KewPA17] is being defaulted to: KEWPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.139--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.139--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idkewPA17] is being defaulted to: IDKEWPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.139--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [deptshName] is being defaulted to: DEPTSHNAME.
[EL Config]: metadata: 2012-11-06 05:42:13.139--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:13.139--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.RegisterUser] is being defaulted to: RegisterUser.
[EL Config]: metadata: 2012-11-06 05:42:13.14--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.RegisterUser] is being defaulted to: REGISTERUSER.
[EL Config]: metadata: 2012-11-06 05:42:13.14--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:13.14--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idregisterUser] is being defaulted to: IDREGISTERUSER.
[EL Config]: metadata: 2012-11-06 05:42:13.14--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [password] is being defaulted to: PASSWORD.
[EL Config]: metadata: 2012-11-06 05:42:13.141--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.InitialReceive] is being defaulted to: InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:13.141--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.InitialReceive] is being defaulted to: INITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:13.141--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [initialReceive_date] is being defaulted to: INITIALRECEIVE_DATE.
[EL Config]: metadata: 2012-11-06 05:42:13.141--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idinitialReceive] is being defaulted to: IDINITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:13.142--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [initialLetter_date] is being defaulted to: INITIALLETTER_DATE.
[EL Config]: metadata: 2012-11-06 05:42:13.142--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:13.142--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [dateTo_inspect] is being defaulted to: DATETO_INSPECT.
[EL Config]: metadata: 2012-11-06 05:42:13.143--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.143--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [initialLetter_ref] is being defaulted to: INITIALLETTER_REF.
[EL Config]: metadata: 2012-11-06 05:42:13.143--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.KewPA17_2] is being defaulted to: KewPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:13.144--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.KewPA17_2] is being defaulted to: KEWPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:13.144--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idkewPA17_2] is being defaulted to: IDKEWPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:13.144--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.KewPA17_3] is being defaulted to: KewPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:13.144--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.KewPA17_3] is being defaulted to: KEWPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:13.145--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idkewPA17_3] is being defaulted to: IDKEWPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:13.145--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field process] is being
[Updated on: Mon, 05 November 2012 17:12] Report message to a moderator
| Re: EntityManagerFactory (Eclipselink RCP) return NullPointerException [message #990516 is a reply to message #974198] |
Wed, 12 December 2012 15:50  |
Azi Azwady Jamaludin Messages: 10 Registered: October 2012 |
Junior Member |
Hi Shaun,
Sorry I've been missing for long time. I don't know wether the connection is established or not but it keep saying that ServerSession Connection is connected.
But when comes to the SWT, there is an exception occurs. If the login is successful, then data should be in place where JFace can extract the data and display it. But nothing is display.
I've put some data in the table previously. I've also rewrite my binding code. But still no luck. I'm also forward this error in SWT's forum as I'm assuming the problem happen at SWT side. Here,i'm posting the new stacktrace as i'm configuring that the problem is from Persistence side.
In my EntityManagerFactory, i'm using the gemini as the PersistenceProvider and point my persistence.xml's path as the Meta-Persistence in MANIFEST.MF (META-INF).
Why the access, target entity, column name and alias name is being default?. What is that mean?.
Here I'm attaching the new stacktrace (.rtf), my entitymanager (.java) and persistence (.xml)
Current Time: Thu May 23 12:48:15 EDT 2013
Powered by FUDForum. Page generated in 0.09180 seconds
