Home » Eclipse Projects » Eclipse 4 » Apply Settings of Application Model
Apply Settings of Application Model [message #974019] Tue, 06 November 2012 15:07 Go to next message
Aljoscha Steffens is currently offline Aljoscha Steffens
I'm working with eclipse 3.7 since about a month now but I switched to eclipse 4 due to the event system. But I can't really start since my application model doesn't work. It's probably a stupid mistake but since I already wasted a couple of hours and a lot more brain cells on it, I'll try it here.
This is what I did (about a million times):
start eclipse 4.2 (it's not SR1, but I will come to that issue later) with "E4 CSS Spy" and "Eclipse e4 Tools" installed. Next I choose File - new - other - Eclipse 4 - Eclipse 4 Application Project. I leave everything as it is (except for the name) and I don't generate an activator. Then I select the product and launch an Eclipse application. I close the application, open the Application.e4xmi file and change the size of the trimmed window, save, restart the application with "launch an eclipse application" and nothing changed.
I know, my description is probably far to detailed, but it's so simple that I can't imagine doing a mistake somewhere.
Why I didn't use 4.2 SR1:
When I start Eclipse there pop up two error messages:
"egit could not detect where git is installed"
and
"The HOME variable was not set".
As far as I can tell, I don't need Git since its for some reposetory stuff. And if I'm wrong, if it must be installed, why doesn't it come with Eclipse?
I hope you can help me, I'm really stuck.
Aljo
Re: Apply Settings of Application Model [message #974960 is a reply to message #974019] Wed, 07 November 2012 08:20 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
Am 07.11.12 13:56, schrieb Aljoscha Steffens:
> I'll try it here.
The problem is that your 2nd start will use the restored state from the
previous session! You can either:
a) pass -clearPersistedState
b) check the clear workspace flag
in your launch configuration.
Tom
Re: Apply Settings of Application Model [message #974966 is a reply to message #974960] Wed, 07 November 2012 08:33 Go to previous messageGo to next message
Sopot Cela is currently offline Sopot Cela
In the latest e4 tools version there is a possibility to select in the wizard to have the cPS flag by default when you create the app.
Re: Apply Settings of Application Model [message #975292 is a reply to message #974966] Wed, 07 November 2012 14:19 Go to previous message
Thanks alot! But I don't understand why it's not default. Is it so unusual to change the Application model freaquently?
Previous Topic:friends of e4.ui...?
Next Topic:Cannot open .e4xmi in 4.2.1
Current Time: Sun May 19 20:33:28 EDT 2013
Powered by FUDForum. Page generated in 0.05976 seconds
