Home » Modeling » TMF (Xtext) » Serializing unassigned keyword needed by quick fix
Serializing unassigned keyword needed by quick fix [message #972552] Mon, 05 November 2012 13:19 Go to next message
Stephan Herrmann is currently offline Stephan Herrmann
I've implemented a quick fix (using semantic modification) which needs to generate an element with an unassigned keyword, like this:
Foo:
 (('bar1' bar=[Bar1]) | ('bar2' bar=[Bar2])) more=More;
where Bar1 and Bar2 have the expected common super-type Bar.
Obviously, the serializer cannot decide whether to insert a 'bar1' or 'bar2' keyword.
After reading about "Unassigned Text" at http://www.eclipse.org/Xtext/documentation.html#serialization I figured I'd need a value serializer, but binding a custom IValueSerializer (watchout, there are 2 interfaces of this name), did not make any difference. It looks like serialization on behalf of a quick fix doesn't use this kind of value serializer?
I managed to achieve the same effect by sub-classing MyDslSyntacticSequencer. However, this approach is a pretty bumpy road: lots of "restriction" warnings and the field SyntacticalContext.semanticObject, which I need for my implementation, isn't even accessible.
What is the recommended way to handle this?
- Should the syntactic sequencer actually use a value serializer where it is not?
- Is there another hook that I could use to customize serialization?
- Is customizing the sequencer actually a good approach (and should SyntacticalContext be opened up more, to facilitate this approach?) ?
cheers,
Stephan
Re: Serializing unassigned keyword needed by quick fix [message #972716 is a reply to message #972552] Mon, 05 November 2012 16:15 Go to previous message
Sebastian Zarnekow is currently offline Sebastian Zarnekow
Hi Stephan,
This looks like a bug to me. I filed
https://bugs.eclipse.org/bugs/show_bug.cgi?id=393606
You may want to comment on that one.
Regarding the SyntaticSequencer (you're a real code archeologist :-):
Yes, it is clearly meant to be extended. A first glance at the code
suggests that there was a misconception about the visibility rules of
protected inner classes. Please share your thoughts in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=393608
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 05.11.12 19:19, schrieb Stephan Herrmann:
> Foo:
> 'bar2' keyword.
> What is the recommended way to handle this? - Should the syntactic
> cheers,
> Stephan
Previous Topic:Hand over properties from Maven to MWE2 Workflow Descriptor
Next Topic:Newline removed when model gets updated
Current Time: Tue May 21 23:32:40 EDT 2013
Powered by FUDForum. Page generated in 0.01584 seconds
