Home » Eclipse Projects » NatTable » Excel Export fires NullPointerException if file dialog is cancelled
icon13.gif  Excel Export fires NullPointerException if file dialog is cancelled [message #956121] Wed, 24 October 2012 04:55 Go to next message
Michi Classen is currently offline Michi Classen
The excel export is continuable, as long as the file dialog handler has not been cancelled. Once the dialog was cancelled, the following error message is thrown:
!STACK 0
at org.eclipse.nebula.widgets.nattable.export.FileOutputStreamProvider.getOutputStream(FileOutputStreamProvider.java:40)
at org.eclipse.nebula.widgets.nattable.extension.poi.PoiExcelExporter.getOutputStream(PoiExcelExporter.java:54)
at org.eclipse.nebula.widgets.nattable.export.NatExporter.exportSingleLayer(NatExporter.java:44)
at org.eclipse.nebula.widgets.nattable.export.command.ExportCommandHandler.doCommand(ExportCommandHandler.java:33)
at org.eclipse.nebula.widgets.nattable.export.command.ExportCommandHandler.doCommand(ExportCommandHandler.java:1)
at org.eclipse.nebula.widgets.nattable.command.AbstractLayerCommandHandler.doCommand(AbstractLayerCommandHandler.java:19)
at org.eclipse.nebula.widgets.nattable.layer.AbstractLayer.doCommand(AbstractLayer.java:152)
at org.eclipse.nebula.widgets.nattable.layer.CompositeLayer.doCommand(CompositeLayer.java:137)
at org.eclipse.nebula.widgets.nattable.grid.layer.GridLayer.doCommand(GridLayer.java:169)
at org.eclipse.nebula.widgets.nattable.NatTable.doCommand(NatTable.java:507)
I'm using the actual software released on Eclipse.org.
Looking at bugzilla, this bug was reported on May '12:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=379923 but never solved.
Ciao,
Michi
[Updated on: Wed, 24 October 2012 09:11]
Report message to a moderator
Re: Excel Export fires NullPointerException if file dialog is cancelled [message #958801 is a reply to message #956121] Fri, 26 October 2012 04:19 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk Fauth
I confirm this bug still exists. As you have found out that there is a bug open on this in bugzilla, please use bugzilla for further conversation. I commented it and assigned it to Edwin as he is most familiar with the export. But to get open bugs into our attention again, you should consider commenting the bug instead of writing in the forum, as the forum is not read that frequently by all of our members. Bugzilla will send emails on changes.
Greez,
Dirk
Re: Excel Export fires NullPointerException if file dialog is cancelled [message #963029 is a reply to message #958801] Mon, 29 October 2012 10:17 Go to previous messageGo to next message
Ok, thanks.
Re: Excel Export fires NullPointerException if file dialog is cancelled [message #972423 is a reply to message #963029] Mon, 05 November 2012 11:11 Go to previous messageGo to next message
Edwin Park is currently offline Edwin Park
Fixed - apologies for the long delay in getting this resolved!
Edwin
Re: Excel Export fires NullPointerException if file dialog is cancelled [message #972486 is a reply to message #972423] Mon, 05 November 2012 12:13 Go to previous message
Hi Edwin, thanks!
Do you have a patch of the fix or a fast instruction to solve the bug?
In addition I noticed another errorneous behavior on export. Running the export a second time, an empty excel sheet is saved and the following exception is thrown:
java.lang.IllegalArgumentException: This Style does not belong to the supplied Workbook. Are you trying to assign a style from one workbook to the cell of a differnt workbook?
at org.apache.poi.hssf.usermodel.HSSFCellStyle.verifyBelongsToWorkbook(HSSFCellStyle.java:801)
at org.apache.poi.hssf.usermodel.HSSFCell.setCellStyle(HSSFCell.java:905)
at org.apache.poi.hssf.usermodel.HSSFCell.setCellStyle(HSSFCell.java:901)
at org.eclipse.nebula.widgets.nattable.extension.poi.PoiExcelExporter.exportCell(PoiExcelExporter.java:113)
at org.eclipse.nebula.widgets.nattable.export.NatExporter.exportLayer(NatExporter.java:167)
at org.eclipse.nebula.widgets.nattable.export.NatExporter$1.run(NatExporter.java:54)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
This bug is also reported in bugzilla
https://bugs.eclipse.org/bugs/show_bug.cgi?id=390522
[Updated on: Tue, 06 November 2012 08:32]
Previous Topic:Sandy
Next Topic:Nattable builder extension
Current Time: Wed May 22 13:34:02 EDT 2013
Powered by FUDForum. Page generated in 0.04904 seconds
