Home » Language IDEs » CDT » OpenCV link problem. Eclipse Juno(collect2: ld returned 1 exit status)
OpenCV link problem. Eclipse Juno [message #961907] Sun, 28 October 2012 14:00 Go to next message
Felipe Garcia is currently offline Felipe Garcia
I can't configure Eclipse properly with OpenCV. Thus I have this problem when linking:
18:57:23 **** Incremental Build of configuration Build (GNU) for project hello01 ****
make all
Making all in src
make[1]: Entering directory `/home/lipiss/workspace/hello01/src'
g++ -g -O2 -o a.out hello01.o
hello01.o: In function `main':
/home/lipiss/workspace/hello01/src/hello01.cpp:55: undefined reference to `cvLoadImage'
make[1]: Leaving directory `/home/lipiss/workspace/hello01/src'
/home/lipiss/workspace/hello01/src/hello01.cpp:65: undefined reference to `cvNamedWindow'
/home/lipiss/workspace/hello01/src/hello01.cpp:68: undefined reference to `cvShowImage'
/home/lipiss/workspace/hello01/src/hello01.cpp:71: undefined reference to `cvWaitKey'
/home/lipiss/workspace/hello01/src/hello01.cpp:74: undefined reference to `cvDestroyWindow'
/home/lipiss/workspace/hello01/src/hello01.cpp:75: undefined reference to `cvReleaseImage'
make[1]: *** [a.out] Error 1
make: *** [all-recursive] Error 1
Can someone tell me the configuration to resolve this linking issue please?
Thank you in advance
Felipe
Re: OpenCV link problem. Eclipse Juno [message #962631 is a reply to message #961907] Mon, 29 October 2012 03:56 Go to previous messageGo to next message
Axel Mueller is currently offline Axel Mueller
You have to link your application against the OpenCV lib.
http://wiki.eclipse.org/CDT/User/FAQ#Adding_C.2FC.2B.2B_External_Libraries
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Re: OpenCV link problem. Eclipse Juno [message #963225 is a reply to message #962631] Mon, 29 October 2012 13:01 Go to previous messageGo to next message
Yes. I am aware that I have to link my application against the required lib.
4:26, 18 December 2007 (EST): Neither of these worked for me under Linux. I had to open up the project's properties and go to "C/C++ Build" -> "Settings" and then hit the "Libraries" item under "GCC C++ Linker" heading in the list on the right.
Thank you for the reference. But I think the version Juno is not like that anymore. If someone could tell me how to configure it please? I have no clue where to introduce the libraries.
Re: OpenCV link problem. Eclipse Juno [message #964204 is a reply to message #963225] Tue, 30 October 2012 06:39 Go to previous messageGo to next message
Felipe Garcia wrote on Mon, 29 October 2012 18:01
There is no difference in the Juno version.
Before you ask
- search this forum
- google
Re: OpenCV link problem. Eclipse Juno [message #965004 is a reply to message #964204] Tue, 30 October 2012 19:59 Go to previous messageGo to next message
In the properties menu I can't see: Project->Properties->Tool Settings Tab->C++ Linker->Miscellaneous
That is what I mean. Juno is different. I attached a screenshot to just let you see.
Thank you !
Re: OpenCV link problem. Eclipse Juno [message #965048 is a reply to message #965004] Tue, 30 October 2012 20:49 Go to previous messageGo to next message
David Wegener is currently offline David Wegener
> Thank you !
Is your project a Makefile project or a Managed project (check the
Makefile generation section on the C++ Build properties). If it is a
Makefile project, you have to add the library to the Makefile. I
believe only Managed projects have the Tools tab.
Re: OpenCV link problem. Eclipse Juno [message #965418 is a reply to message #965004] Wed, 31 October 2012 04:08 Go to previous messageGo to next message
Felipe Garcia wrote on Wed, 31 October 2012 00:59
Thank you !
Juno is not different. Your configuration is different. You configured Eclipse to use your own Makefile. You will only get the above Settings Tab when you activate "Generate Makefiles automatically" in Project Properties->C/C++ Build. Then Eclipse will create the Makefiles and you can configure them.
Please have a look at the CDT help first!
Before you ask
- search this forum
- google
Re: OpenCV link problem. Eclipse Juno [message #969886 is a reply to message #965418] Sat, 03 November 2012 12:57 Go to previous message
Totally true!!
That was my problem. When generating the project: Project Type => Makefile Project, and then Generate Makefiles Automatically.
My fault.
Thanks!!!! Rolling Eyes
Previous Topic:Formatter and command line
Next Topic:StringIndexOutOfBoundsException when running project
Current Time: Sun May 19 03:58:38 EDT 2013
Powered by FUDForum. Page generated in 0.01705 seconds
