Home » Eclipse Projects » Gemini » e4 Application with Gemini time out exceptions
e4 Application with Gemini time out exceptions [message #968764] Fri, 02 November 2012 14:39
Thomas Blattner is currently offline Thomas Blattner
I'm using Gemini 1.1.0 RC1 in an Eclipse e4 RCP application.
The app runs fine when started within the IDE.
But when I start the exported RCP product I have some problems.
The application not allways starts. Sometimes I have some weird time out problems like following
!MESSAGE While loading class "org.eclipse.core.internal.registry.CombinedEventDelta", thread "Thread[Refresh Packages,5,main]" timed out waiting (5004ms) for thread "Thread[Start Level Event Dispatcher,5,main]" to finish starting bundle "org.eclipse.equinox.registry_3.5.200.v20120522-1841 [75]". To avoid deadlock, thread "Thread[Refresh Packages,5,main]" is proceeding but "org.eclipse.core.internal.registry.CombinedEventDelta" may not be fully initialized.
Most of the time a start with the -clean option helps.
REFRESH_BUNDLES and WEAVING is disabled, if this might be a root cause for the problems. The startorder of the bundles etc. seems to be ok. As I mentioned, when starting with the clean option it's ok. But should this be a must?
Does anyone else having same problems?
Thx for any response.
Best regards
Thomas
Previous Topic:[Solved]Gemini - Maven-tycho build works on some machines, but not others.
Next Topic:Handling servletRegistry in Felix with Gemini Blueprint
Current Time: Wed May 22 21:51:35 EDT 2013
Powered by FUDForum. Page generated in 0.01615 seconds
