Home » Newcomers » Newcomers » Adding Jar Files to the Build Path
Adding Jar Files to the Build Path [message #968547] Fri, 02 November 2012 10:49 Go to next message
Matt Connors is currently offline Matt Connors
I am writing a java program and want to include 30 or so jar files in the class path.
When I go to Project/Properties/Java Build Path/Libraries I can add jar files one at a time. Is there a way I can indicate that all the jar files in a particular folder are to be included in the build?
Thanks in advance.
Re: Adding Jar Files to the Build Path [message #968671 is a reply to message #968547] Fri, 02 November 2012 12:58 Go to previous messageGo to next message
Larry Parker is currently offline Larry Parker
Choose the option just below "Add JARs..." which is "Add External JARs.." and shift-click or ctrl-click the jars you want added. That's how I add multiple jars.
I'm pretty new to eclipse so if there is a better way then I would like to know too. Very Happy
Re: Adding Jar Files to the Build Path [message #968704 is a reply to message #968671] Fri, 02 November 2012 13:32 Go to previous messageGo to next message
Yes, that worked great.
Many thanks,
Re: Adding Jar Files to the Build Path [message #968745 is a reply to message #968671] Fri, 02 November 2012 14:11 Go to previous message
Russell Bateman is currently offline Russell Bateman
> to know too. :d
If you have a set of disparate JARs that you keep wanting to add to new
projects you're creating frequently, there's a concept of User Library
you can use to create the collection, then you just add that collection
each time.
However, this method plays havoc with .classpath and version-control
systems since it always results in external (non-workspace) paths.
Previous Topic:Class not found
Next Topic:How to run multiple launch files sequentially?
Current Time: Sun May 19 05:17:58 EDT 2013
Powered by FUDForum. Page generated in 0.01562 seconds
