Home » Eclipse Projects » Remote Application Platform (RAP) » New RWT session on browser refresh(On every browser refresh an new RWT session is created)
New RWT session on browser refresh [message #956865] Wed, 24 October 2012 17:30 Go to next message
Karl Hönninger is currently offline Karl Hönninger
After migrating a SWT-Web-Framework to RWT I am now struggling with the situation that on every browser refresh a new session is created (which is not intended).
In the forum I found some older discussions regarding this issue but I am not sure what about the current state for the following setup:
- standalone RWT application
- OperationMode.SWT_COMPATIBILITY
- version 2.0.0.20121001-1623
Here is a test code to reproduce this behaviour:
package org.openxma.demo.ui;
import org.eclipse.rap.rwt.lifecycle.IEntryPoint;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.FormAttachment;
import org.eclipse.swt.layout.FormData;
import org.eclipse.swt.layout.FormLayout;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
public class TestEntryPoint implements IEntryPoint {
public int createUI() {
Display display = new Display();
Shell shell = new Shell(display, SWT.NO_TRIM);
shell.setLayout(new FormLayout());
Text text = new Text(shell,SWT.BORDER);
FormData data = new FormData();
data.left = new FormAttachment(0,100,10);
data.top = new FormAttachment(0,100,10);
text.setLayoutData(data);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
return 0;
Can I somehow continue a session on a browser refresh or use the solution with exitConfirmation also in a standalone RWT application (OperationMode.SWT_COMPATIBILITY)?
Thank you,
best regards,
Karl
Re: New RWT session on browser refresh [message #957419 is a reply to message #956865] Thu, 25 October 2012 03:55 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan Furnadjiev
Hi Karl,
on browser refresh the HTTP session stays the same, but the session
store is cleared. There is already opened enhancement request to support
session recovery:
389949: Allow session recovery
https://bugs.eclipse.org/bugs/show_bug.cgi?id=389949
Best,
Ivan
On 10/25/2012 10:04 AM, Karl Hönninger wrote:
> Hello,
> import org.eclipse.swt.widgets.Display;
> shell.open();
> display.sleep();
> return 0;
> Thank you,
> best regards,
> Karl
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: New RWT session on browser refresh [message #967496 is a reply to message #957419] Thu, 01 November 2012 16:16 Go to previous message
Thank you Ivan,
I see, the clearing of the session store is the reason why the RWT application is reset on browser refresh.
So I will vote for the mentioned enhancement request.
Karl
Previous Topic:Deploy problem
Next Topic:Non working url in browser widget
Current Time: Wed May 22 06:52:32 EDT 2013
Powered by FUDForum. Page generated in 0.02083 seconds
