Home » Modeling » ATL » Iterate through an array and conditional check
Iterate through an array and conditional check [message #967008] Thu, 01 November 2012 08:10
Kosala Yapa is currently offline Kosala Yapa
Hi there,
I have an array of modules sorted to module numbers.
modules=[mod1,mod2,mod3,mod4,mod5,mod8]
I need to iterate through each module and add null modules if there is no module for a module number. For example, in the above array, need to add null modules between mod5 and mod8.
Then the result is,
Allmodules=[mod1,mod2,mod3,mod4,mod5,null,null,mod8]
How to write this in atl to get the 2nd array from the 1st array?
Thanks in advance!
K
Previous Topic:Debugging an ATL module, which has external methods
Next Topic:Many to one transformation
Current Time: Tue May 21 07:02:53 EDT 2013
Powered by FUDForum. Page generated in 0.01520 seconds
