Hello every one
i try to export class diagram to XML format
so i made right click on "model.di" and choose export
my question is:
which one of these options i must select to convert model to xml format(see attachment)?
thank you in advance
Hello Goood Guy,
i built a simple class diagram using Papyrus and i want to view representation of UML diagram in xml format
i want to see how UML diagram represent in xml (tags)and want to know how class,attribute,generalization relationship...etc represented in xml ?
and the modification i meant is :for example add new integer property to class in xml and then view it in UML?
