| Stereotypes and root element [message #965693] |
Wed, 31 October 2012 08:42  |
Carsten Reckord Messages: 16 Registered: June 2012 |
Junior Member |
Hi there,
I'm having some trouble with an in-place transformation of a UML model.
During the transformation, some new nested elements are created in the model
and a stereotype is applied to them. This works great during the
transformation.
But when running the transformation with the Operational QVT Runner, the
updated UML file does not contain the stereotype applications. After some
debugging, I found the problem:
QvtLaunchConfigurationDelegateBase.saveTransformationResult(...) essentially
restricts the contents of the saved resource to the input model extent,
which consists only of the Model element. The stereotype application
instances, which are directly contained in the resource as siblings of the
model, are removed from the resource by that logic.
So, is there a way to add these elements to the model extent so they are
retained in the result? Should there be some metamodel specific filtering
going on that knows about UML's stereotype handling?
Carsten
| Re: Stereotypes and root element [message #965715 is a reply to message #965693] |
Wed, 31 October 2012 09:02   |
Ed Willink Messages: 3171 Registered: July 2009 |
In the absence of a more helpful reply...
Interesting, I wasn't sure whether in-place transformations were supported.
I'm afraid that you are now an expert, so your discoveries are probably
correct. Could you please submit a Bugzilla with your observations and
possibly a patch if you keen on it.
It is unfortunate that projects such as ATL, QVTo, Acceleo, OCL all have
to provide their own (partial and inconsistent) attempts at stereotype
support. The new pivot-based Eclipse OCL endeavours to provide a
coherent merged UML and OCL meta-model in which stereotypes are
supported. Once QVTo migrates to this support there should be more
uniformity and consistency. GIven the limited committer resources, my
best guess is that this might be in the 2014 release.
Ed Willink
On 31/10/2012 12:42, Carsten Reckord wrote:
> Hi there,
> model. During the transformation, some new nested elements are created
> in the model and a stereotype is applied to them. This works great
> during the transformation.
> the updated UML file does not contain the stereotype applications.
> After some debugging, I found the problem:
> essentially restricts the contents of the saved resource to the input
> model extent, which consists only of the Model element. The stereotype
> application instances, which are directly contained in the resource as
> siblings of the model, are removed from the resource by that logic.
> are retained in the result? Should there be some metamodel specific
> filtering going on that knows about UML's stereotype handling?
> Best regards,
> Carsten
| Re: Stereotypes and root element [message #987413 is a reply to message #987411] |
Mon, 26 November 2012 09:13   |
Additional features for the QVTo language should be raised as OMG issues
at OMG.
Additional features for the QVTo tooling should be raised as Bugzillas,
but do not expect much response until we have migrated to underlying
Xtext-based tooling. We are very short of resources, so if you want to
help ...
Ed Willink
On 26/11/2012 14:02, Carsten Reckord wrote:
> Hi Daniel,
> On 15.11.2012 15:03, Daniel Scholz wrote:
>> how did you manage to apply the stereotype? I'm having some trouble applying stereotypes on newly created elements during an in-place transformation. My input model has the (Modal Sequence Diagram) profile applied and I can get the stereotype and its values from messages that I created in the editor beforehand. But I cannot create a new standard element (let's say a UML message) and apply the same stereotype. isStereotypeApplicable() -> false..
> Strange, that just worked for me. I couldn't figure out how to apply a
> profile, so I'm currently requiring the model to already have the profile
> applied. But other than that, it just worked. I'm currently doing it like this:
> mapping Package::usage (used : Package) : Usage {
> init {
> result := self.createUsage(used);
> let s : Stereotype =
> result.getApplicableStereotype("Dependencies::UsageCount") in
> result.applyStereotype(result.stereotype);
> name := self.name+"_uses_"+used.name;
> result.getAppliedStereotype("Dependencies::UsageCount") in
> result.setValue(s, "count", 0);
> Can you post the relevant snippets of how you are trying to apply your
> Stereotype?
| Re: Stereotypes and root element [message #987416 is a reply to message #987413] |
Mon, 26 November 2012 09:17  |
Apologies. Reply to wrong thread.
Ed Willink
On 26/11/2012 14:13, Ed Willink wrote:
> Hi
> issues at OMG.
> Bugzillas, but do not expect much response until we have migrated to
> underlying Xtext-based tooling. We are very short of resources, so if
> you want to help ...
> Regards
> Ed Willink
>> Hi Daniel,
>> profile
>> like this:
>> init {
>> Stereotype?
FUDForum. Page generated in 0.02902 seconds
