Home » Modeling » Papyrus » [Solved] How to set return type of operation?(The "UML" Tab in properties view does not contain an editor for return type and in "Advanced" tab it's not editable. )
[Solved] How to set return type of operation? [message #963042] Mon, 29 October 2012 10:26 Go to next message
Robert Wloch is currently offline Robert Wloch
I was wondering how one is supposed to set the return type of operations in class diagrams in Papyrus 0.9.1?
Steps to reproduce:
1. Create new Papyrus UML project with class diagram.
2. In the diagram create class "Foo" via palette's "Class" tool.
3. Add operation "bar" via palette's "Operation" tool.
4. Select operation "bar" and go to "UML" tab in properties view
Expected: Can set the return type with an appropriate editor.
Found: No editor for return type.
5. Go to tab "Appearance". There's a checkbox for showing the return type and it is checked. So I suppose one should be able to set the return type.
6. Go to tab "Advanced" and scroll down to "type". Double clicking the cell editor has no effect.
7. Open the menu of the property view and "Customize Papyrus Properties View".
8. Make a copy of the "UML" configuration.
9. Edit that copy.
10. Filter for "SingleOperation"
11. Have a look at how the "name" property editor is configured and do the same for the SingleOperation.type property.
12. Save the modified configuration.
13. Go to Papyrus preference page -> "Properties View" and disable the original "UML" properties view and enable the modified copy.
14. Go back to the class diagram, select something else and a different tab in the properties view then select the operation "bar" again.
15. Go to the "UML" tab and find the new property editor for "type" but it is disabled.
So first of all: Big compliment for such an extraordinary configurable properties view! That's just frelling awesome! Cool
Second: Is there a way to edit the return type of an operation or is it a bug?
Robert
Edit:
I thought I could out smart the property editor by manually editing the UML file with a text editor and just append the "type" attribute from a property I created as a template didn't work. Papyrus wouldn't event load the model anymore after that although the id of the type is valid as it's used in the property already.
Also, editing the UML model with the sample reflective ecore editor had the same result as step #6 above.
[Updated on: Tue, 30 October 2012 02:49]
Report message to a moderator
Re: How to set return type of operation? [message #963281 is a reply to message #963042] Mon, 29 October 2012 13:52 Go to previous messageGo to next message
Goood Guy is currently offline Goood Guy
Member
  • add operation
  • open properties view for operation
  • add owned parameter for operation
  • set "direction" of the parameter to "return"
Re: How to set return type of operation? [message #963973 is a reply to message #963281] Tue, 30 October 2012 02:48 Go to previous messageGo to next message
Thanks for the clarification I never thought the return value would be a parameter.
Re: How to set return type of operation? [message #964357 is a reply to message #963973] Tue, 30 October 2012 09:04 Go to previous messageGo to next message
Christian W. Damus is currently offline Christian W. Damus
> a parameter.
It used to be even better than that: an earlier UML 2.x revision
permitted *multiple* return parameters, which actually several modern
programming languages implement. But that made the operation's type
rather ambiguous (perhaps OCL would have interpreted it as an anonymous
TupleType, but UML doesn't have such construct).
Re: How to set return type of operation? [message #964742 is a reply to message #964357] Tue, 30 October 2012 15:14 Go to previous messageGo to next message
HI
UML also allows any number of 'out' or 'inout' parameters. These lack
coherent OCL syntax or semantics.
Since OCL has no assignment support, I guess that an anonymous Tuple is
unavoidable to increase the connectivity of the normal anonymous 'result'.
UML doesn't have any nested Collection types either. Both UML and OCL
have a bit of mutual catching up to do.
Ed Willink
>> be a parameter.
> anonymous TupleType, but UML doesn't have such construct).
Re: How to set return type of operation? [message #965157 is a reply to message #964742] Tue, 30 October 2012 22:59 Go to previous message
Hi, Ed.
"Yep" on all counts.
Although, for this particular case, I think UML actually has a
constraint (since 2.2?) that an operation must have not more than one
return parameter. Formerly, when there was more than one return, the
operation type was constrained to be unset.
cW
On 2012-10-30 19:14:23 +0000, Ed Willink said:
> HI
> 'result'.
> Regards
> Ed Willink
>>> a parameter.
Previous Topic:Automatic Generation of Diagrams.
Next Topic:Papyrus and FUML
Current Time: Tue May 21 02:25:32 EDT 2013
Powered by FUDForum. Page generated in 0.02460 seconds
