Home » Eclipse Projects » EGit » Rename merge does not work - is there any workaround?(The lack of this feature makes any serious refactoring cumbersome.)
Rename merge does not work - is there any workaround? [message #964820] Tue, 30 October 2012 16:31 Go to next message
Marton Sigmond is currently offline Marton Sigmond
Member
Try the following steps, do everything in the IDE:
1) Create a Java project, a Java interface in it, and a method in that interface.
2) Create a Git project around it, and commit an initial revision.
3) Add a new method to the beginning of the interface (before the original method), and commit the change.
4) Create a new branch from the initial revision, and checkout that branch.
5) Rename the interface (or move it to another package), and commit the change.
6) Add a new method to the end of the interface (after the original method), and commit the change.
7) Finally try to merge the new branch with the master.
What you will get is an ugly conflict.
However, if you followed the above steps closely, you can see that it should be a non-conflicting merge.
Also, if I perform the last step in the command line, the merge will happen seamlessly.
This is quite unfortunate as it makes refactoring cumbersome.
Is there any workaround for this problem?
Has anyone filed a bug for this yet?
Marton
Re: Rename merge does not work - is there any workaround? [message #965005 is a reply to message #964820] Tue, 30 October 2012 20:01 Go to previous messageGo to next message
Chris Aniszczyk is currently offline Chris Aniszczyk
This is currently being implemented, follow these:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=380314
https://git.eclipse.org/r/#/c/8113/
Re: Rename merge does not work - is there any workaround? [message #965371 is a reply to message #965005] Wed, 31 October 2012 03:17 Go to previous messageGo to next message
Member
Thanks!
Best Regards,
Marton Sigmond
Software Design Engineer
Re: Rename merge does not work - is there any workaround? [message #1006431 is a reply to message #964820] Thu, 31 January 2013 05:51 Go to previous message
Jan Hoskens is currently offline Jan Hoskens
This thread was started two months ago, the linked bug report also shows no real change for two months. Isn't this a critical one? Is there no progress on this?
We're switching to Git, but the rename merge problem is a real show stopper for the EGit plugin. How can anyone work with this plugin on a serious project while this bug isn't patched? We're now considering dumping EGit for SmartGit as the bug went silent two months ago.
Jan
Previous Topic:"Building Workspace" slow with EGit 1.1 and Nightly
Next Topic:How to separate Eclipse and Git metadata
Current Time: Mon May 20 07:30:57 EDT 2013
Powered by FUDForum. Page generated in 0.02863 seconds
