Home » Language IDEs » CDT » Build Error : illegal character in path
Build Error : illegal character in path [message #962387] Sun, 28 October 2012 23:13 Go to next message
cah gandul is currently offline cah gandul
index.php/fa/12111/0/Hallo,
I'm newbie in eclipse and C++ programming Very Happy
I have problem with compiling C++ in eclipe (as shown in the attachment),
the source code compiled and ran well at the first time (correct result), but unfortunately, if i change something (for example input data) in the source code, the result still calculate based on the first source code. anyone could help me?
thank you be4.
regards,
cg.
Re: Build Error : illegal character in path [message #964208 is a reply to message #962387] Tue, 30 October 2012 06:42 Go to previous messageGo to next message
Axel Mueller is currently offline Axel Mueller
The problem is caused by the space in your project name. You should rename it.
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Re: Build Error : illegal character in path [message #964777 is a reply to message #964208] Tue, 30 October 2012 15:45 Go to previous message
it's solved. Laughing
thank you.
best regards,
cg.
Previous Topic:I install the Eclipse IDE for C/C++ Developers, but I find I could not add JDT
Next Topic:my application still run after closing(ubuntu)
Current Time: Sat May 25 04:11:41 EDT 2013
Powered by FUDForum. Page generated in 0.01799 seconds
