| Can't build headless featurebased RCP [message #964599] |
Tue, 30 October 2012 12:53  |
Missing name Missing name Messages: 3 Registered: October 2012 |
Junior Member |
I have troubles to get a headless featurebased RCP build. The error is: productBuild.xml:69: Unable to find feature: myotherfeature
My directory structure:
- workspace
|- myfeature
| |- feature.xml
|- myotherfeature
| |- headless
| | |- build.properties
| |- my.product
| |- feature.xml
As you see, the features were created in the workspace, there is no dedicated "features" folder, because the features are "feature-projects" generated by eclipse in the workspace.
The build.properties file is a copy from the headless-directory of pde-plugin. I set following:
topLevelElement = feature
topLevelElementd = myotherfeature
product=/myotherfeature/my.product
builddirectory=<path to my workspace>
base=<path to parent directory of my eclipse-root>
baseLocation=<points to the eclipse root>
All other settings are irrelevant for my problem, I think.
The product-file has only one dependency: myotherfeature. This feature has its own dependencies, like myfeature and other plugins/features.
I can build the RCP in eclipse by clicking the link on the right of the product-editor overview-tab. AND also I can start the RCP directly using the "Start Eclipse application" link on the left.
If I change in build.properties the product-property to something, that does not exist, then there is the error, that it can't find the element in <workspace>/features/myotherfeature/my.product. Why it is searching in <workspace>/features and not just only in <workspace>? Maybe this is a hint for my problem.
Maybe this is a bug, because I can build another project, which is based on plugins only, there are no features.
Do I miss something? Any suggestions?
| Re: Can't build headless featurebased RCP [message #966930 is a reply to message #964599] |
Thu, 01 November 2012 06:50  |
Junior Member |
I think, I have found the problem:
In BuildTimeSiteFactory.java (org.eclipse.pde.build Plugin, org.eclipse.pde.internal.build.site - Package), there is the method: findFeatureXMLs(). It contains this code:
if (file.exists()) {
//path is a feature itself
features.add(file);
continue;
} else if (new File(sitePaths[i], DEFAULT_FEATURE_LOCATION).exists()) {
//path is a eclipse root and contains a features subdirectory
foundFeatures = Utils.findFiles(new File(sitePaths[i]), DEFAULT_FEATURE_LOCATION, Constants.FEATURE_FILENAME_DESCRIPTOR);
} else {
// treat as a flat directory containing features
foundFeatures = Utils.findFiles(new File(sitePaths[i]), ".", Constants.FEATURE_FILENAME_DESCRIPTOR); //$NON-NLS-1$
The problem is, that while creating plugins and features in eclipse, the script creates a "features" folder in the build folder. I set my "build-folder" to my workspace folder. This will force the if-else if-else code to run into the else-if instead of the else, because the script creates the "features" folder before.
FUDForum. Page generated in 0.05807 seconds
