Home » Language IDEs » PDT » Get Eclipse to automatically convert smart characters
Get Eclipse to automatically convert smart characters [message #894583] Mon, 09 July 2012 13:31 Go to next message
David Hollingshead is currently offline David Hollingshead
Can I get Eclipse to automatically convert smart quotes, dashes, and ellipses to their UTF-8 equivalent? It seems to want to save the smart characters and they show up as gobbledygook on various servers.
Re: Get Eclipse to automatically convert smart characters [message #964465 is a reply to message #894583] Tue, 30 October 2012 10:39 Go to previous message
Thomas   is currently offline Thomas
As far as I know, in order to make sure all new files are UTF-8, you should right-click on your project, select Properties -> Resource then under Text file encoding select "Other" and choose UTF-8. However according to http://www.eclipse.org/forums/index.php?t=msg&th=29511 there may be some problems in that.
In order to convert all of your current files to UTF-8, I would suggest using one of the methods described in the Super User question "Batch-convert files for encoding". (I would post the link to it, however I have fewer than 5 posts).
Note that if you don't already, you should have all of your files under source control just in case the conversion process goes wrong.
Previous Topic:What i miss
Next Topic:How to use the PHP debugger under XAMPP
Current Time: Fri May 24 23:19:41 EDT 2013
Powered by FUDForum. Page generated in 0.02005 seconds
