Home » Eclipse Projects » Jubula » MissingResourceExceptions in client log file(MissingResourceExceptions in client log file)
MissingResourceExceptions in client log file [message #964040] Tue, 30 October 2012 04:03 Go to next message
John Lawton is currently offline John Lawton
have installed jubula standalone version 1.3.0 and setup a connection to MySQL.
On first connection to the database there is no obvious problem - the default projects (unbound modules) are loaded as exepected.
But, when I inspect the client log file there is a large number of Missing Resource Exceptions - all of which are reporting "No entry found for key: <name>" - a copy of the client log file is attached.
I have not yet validated whether my existing test suites work correctly with version 1.3.0, but I am concerned that any test cases that simulate keyboard input may no longer work as expected.
These errors are repeatable (i.e. if I reinstall and then re-connect to a clean database I get the same log file entries). I have tried this on both Win7 and WinXP bbut get the same result.
But these errors do not occur when I use jubula 1.2.1.
Does anyone have suggestions as to what might be causing these errors - and whether I should be concerned?
John
Re: MissingResourceExceptions in client log file [message #964131 is a reply to message #964040] Tue, 30 October 2012 05:25 Go to previous messageGo to next message
Achim Loerke is currently offline Achim Loerke
Hi John,
I cannot see the log file. Please check if you really submitted one. You may also file a bug against Jubula and attach the log there.
Achim
Re: MissingResourceExceptions in client log file [message #964184 is a reply to message #964131] Tue, 30 October 2012 06:23 Go to previous messageGo to next message
Hi Achim
Thanks for looking at this.
I have created a new jubula bug report (bug #393124) and have attached the log file to that.
John
P.S. There seems to be a bug in the file attachment process in the Jubula Forum - when I created the initial post I tried several times to attach two files (one a screenshot and the other the log file) but the forum page kept crashing! I then tried to submit with only a single file attachment - and apparently even that didn't work properly. And, I have just tried to reply to your message with the client log attached - and that failed also! But there was no problem attaching the same client log to the bugzilla report?!?
Re: MissingResourceExceptions in client log file [message #964340 is a reply to message #964184] Tue, 30 October 2012 08:50 Go to previous message
John Lawton wrote on Tue, 30 October 2012 11:23
The forum software is maintained by the Eclipse Foundation staff. If this keeps happening please file a bug.
Previous Topic:how to configure and connect MySql Database with eclipse for accessing table from database
Next Topic:Jubula: Unable to Carry forward session in Web application (Version 1.3)
Current Time: Fri May 24 03:21:30 EDT 2013
Powered by FUDForum. Page generated in 0.09193 seconds
