Home » Modeling » TMF (Xtext) » endless Loop with extern lexer
endless Loop with extern lexer [message #964155] Tue, 30 October 2012 05:52
Sebastian Glonner is currently offline Sebastian Glonner
Hello
I am writing a xml grammar with xtext. Therefore i am using an external lexer.
My problem appears when starting content assist while inside a RULE_STRING inside a tag. Example:
<sometag someattr="somestring"> </sometag>
pressing ctrl + space inside >"somestring"< will cause a endless loop.
I tryed to investigate why this is happening.
Because i am not allowing rule_pcdata inside tags with my tagMode variable.
this is the function of the lexer.
    public final void mRULE_PCDATA() throws RecognitionException {
        try {
            int _type = RULE_PCDATA;
            int _channel = DEFAULT_TOKEN_CHANNEL;
            // ../com.groupion.ixml.sdk.xtext/src/com/groupion/ixml/sdk/xtext/lexer/XMLLexer.g:39:13: ({...}? => (~ ( ( '<' | '%' ) ) )+ )
            // ../com.groupion.ixml.sdk.xtext/src/com/groupion/ixml/sdk/xtext/lexer/XMLLexer.g:39:15: {...}? => (~ ( ( '<' | '%' ) ) )+
            if ( !(( !tagMode )) ) {
                throw new FailedPredicateException(input, "RULE_PCDATA", " !tagMode ");
            // ../com.groupion.ixml.sdk.xtext/src/com/groupion/ixml/sdk/xtext/lexer/XMLLexer.g:39:31: (~ ( ( '<' | '%' ) ) )+
            int cnt2=0;
            loop2:
            do {
                int alt2=2;
                int LA2_0 = input.LA(1);
                if ( ((LA2_0>='\u0000' && LA2_0<='$')||(LA2_0>='&' && LA2_0<=';')||(LA2_0>='=' && LA2_0<='\uFFFF')) ) {
                    alt2=1;
                switch (alt2) {
            	case 1 :
            	    // ../com.groupion.ixml.sdk.xtext/src/com/groupion/ixml/sdk/xtext/lexer/XMLLexer.g:39:31: ~ ( ( '<' | '%' ) )
            	    if ( (input.LA(1)>='\u0000' && input.LA(1)<='$')||(input.LA(1)>='&' && input.LA(1)<=';')||(input.LA(1)>='=' && input.LA(1)<='\uFFFF') ) {
            	        input.consume();
            	    else {
            	        MismatchedSetException mse = new MismatchedSetException(null,input);
            	        recover(mse);
            	        throw mse;}
            	    break;
            	default :
            	    if ( cnt2 >= 1 ) break loop2;
                        EarlyExitException eee =
                            new EarlyExitException(2, input);
                        throw eee;
                cnt2++;
            } while (true);
            state.type = _type;
            state.channel = _channel;
        finally {
And the endless loop happening because he runs into the
and that seam to happen because the current sign is not consumed.
for example simply adding "input.comsumed()" before the exception will be thrown causes the endless loop to disapear.
Am i doing something wrong or might this happen cause of the not completly supported extern lexer / xml grammar. And what would be the best workaround for this problem ?
I am not sure why the predicate is failing anyway.
the rule_pcdata "is not allowed" inside tags and should not be called?
The parsing/lexing without content assist and in all other cases works great!
I added my xtext file and the external lexer.
Thanks for any suggestions.
lexer grammar XMLLexer;
@header {
package com.groupion.ixml.sdk.xtext.lexer;
// Hack: Use our own Lexer superclass by means of import.
// Currently there is no other way to specify the superclass for the lexer.
import org.eclipse.xtext.parser.antlr.Lexer;
@members {
    boolean tagMode = true;
KEYWORD_9 : '<?xml version="1.0" encoding="UTF-8"?>';
KEYWORD_8 : { tagMode }?=> 'DOCTYPE ixml SYSTEM';
KEYWORD_7 : { tagMode }?=> 'ixml';
KEYWORD_4 : { tagMode }?=> '/>' { tagMode = false; } ;
KEYWORD_5 : '<!' { tagMode = true; } ;
KEYWORD_6 : '</' { tagMode = true; } ;
KEYWORD_1 : '<' { tagMode = true; } ;
KEYWORD_2 : { tagMode }?=> '=';
KEYWORD_3 : { tagMode }?=> '>' { tagMode = false; } ;
RULE_TAG_NAME : { tagMode }?=> RULE_ID ':' RULE_ID?;
RULE_PCDATA : { !tagMode }?=> ~(('<'|'%'))+;
RULE_ML_COMMENT : '<!--' ( options {greedy=false;} : . )* '-->';
RULE_IXML_VAR : '%' (RULE_IXML_IDENT ('[' (RULE_IXML_VAR|RULE_IXML_IDENT)? ']'|'.' RULE_IXML_IDENT)*)? '%'?;
fragment RULE_IXML_IDENT : ('a'..'z'|'A'..'Z'|'_'|'0'..'9')+;
RULE_CDATA : '<![CDATA[' ( options {greedy=false;} : . )*']]';
//define rules from org.eclipse.xtext.common.Terminals
RULE_ID : { tagMode }?=> '^'? ('a'..'z'|'A'..'Z'|'_') ('a'..'z'|'A'..'Z'|'_'|'0'..'9')*;
RULE_INT : { tagMode }?=> ('0'..'9')+;
RULE_STRING : { tagMode }?=> ('"' ('\\' ('b'|'t'|'n'|'f'|'r'|'u'|'"'|'\''|'\\')|~(('\\'|'"')))* '"'|'\'' ('\\' ('b'|'t'|'n'|'f'|'r'|'u'|'"'|'\''|'\\')|~(('\\'|'\'')))* '\'');
RULE_SL_COMMENT : '//' ~(('\n'|'\r'))* ('\r'? '\n')?;
RULE_WS : { tagMode }?=> (' '|'\t'|'\r'|'\n')+;
RULE_ANY_OTHER : { tagMode }?=> .;
grammar com.groupion.ixml.sdk.xtext.IXML with org.eclipse.xtext.common.Terminals
generate iXML "my url"
IXML:
	'<!''DOCTYPE ixml SYSTEM' dtdUrl = STRING '>'
	// Dirty fix: Allow pcdata to allow whitespaces here
	PCDATA
	rootTag = RootTag
RootTag: {rootContent}
	'<' 'ixml' '>'
		(content += TagContent)*
	'</' 'ixml' '>'
Tag:
	StdTag | EmptyTag
StdTag:
	startTag = StartTag
	endTag = EndTag
StartTag:
	'<' name = TagName WS? attributes += Attribute* '>'
EndTag:
	'</' name = TagName '>'
EmptyTag:
	'<' name = TagName WS? attributes += Attribute* '/>'
TagContent:
	Tag | {pcdata} PCDATA | {ixml_var} IXML_VAR | {cdata} CDATA
Attribute:
	name = ID '=' (value = STRING) WS?
TagName:
	ID | TAG_NAME
terminal TAG_NAME:
	ID':'ID?
terminal PCDATA:
 * change default comment to html comments
terminal ML_COMMENT :
terminal fragment IXML_IDENT :
terminal IXML_VAR :
	'%'(IXML_IDENT( '[' (IXML_VAR | IXML_IDENT)? ']' | '.'IXML_IDENT )*)?'%'?
terminal CDATA:
	'<![CDATA[' -> ']]'
Previous Topic:Eclipse/Xtext crashing
Next Topic:XbaseScopeProvider.createTypeScope removed in Xtext 2.4
Current Time: Sun May 26 00:58:00 EDT 2013
Powered by FUDForum. Page generated in 0.01761 seconds
