Home » Eclipse Projects » Virgo » Problems after upgrading to Spring 3.1.2(java.lang.ClassNotFoundException: org.springframework.web.SpringServletContainerInitializer)
Problems after upgrading to Spring 3.1.2 [message #953608] Mon, 22 October 2012 07:40 Go to next message
Thorsten Schlathölter is currently offline Thorsten Schlathölter
I tried to upgrade the user region of Virgo 3.5.0 from Springframework 3.0.5 to version 3.1.2.
I followed the following FAQ:
http://wiki.eclipse.org/Virgo/FAQ#How_can_I_change_the_version_of_Spring_framework_in_the_user_region.3F
The problem is now that I get the following error when my plan is loaded:
[2012-10-22 12:28:11.428] ERROR start-signalling-5           org.apache.catalina.startup.ContextConfig                         The ServletContentInitializer [org.springframework.web.SpringServletContainerInitializer] could not be created java.lang.ClassNotFoundException: org.springframework.web.SpringServletContainerInitializer
	at org.eclipse.gemini.web.tomcat.internal.loading.BundleWebappClassLoader.loadClass(BundleWebappClassLoader.java:307)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
	at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319)
	at java.lang.Class.forName0(Native Method)
	at java.lang.Class.forName(Class.java:247)
	at org.apache.catalina.startup.ContextConfig.getServletContainerInitializer(ContextConfig.java:1601)
	at org.apache.catalina.startup.ContextConfig.processServletContainerInitializers(ContextConfig.java:1519)
	at org.apache.catalina.startup.ContextConfig.webConfig(ContextConfig.java:1222)
	at org.apache.catalina.startup.ContextConfig.configureStart(ContextConfig.java:855)
	at org.apache.catalina.startup.ContextConfig.lifecycleEvent(ContextConfig.java:345)
	at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119)
	at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:90)
	at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5161)
	at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
	at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:895)
	at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:871)
	at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:615)
	at org.eclipse.gemini.web.tomcat.internal.TomcatServletContainer.startWebApplication(TomcatServletContainer.java:125)
	at org.eclipse.gemini.web.internal.StandardWebApplication.start(StandardWebApplication.java:95)
	at org.eclipse.virgo.web.core.internal.WebBundleLifecycleListener.onStarted(WebBundleLifecycleListener.java:122)
	at org.eclipse.virgo.kernel.install.artifact.internal.StandardArtifactStateMonitor.onStarted(StandardArtifactStateMonitor.java:271)
	at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.asyncStartSucceeded(AbstractInstallArtifact.java:319)
	at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.access$0(AbstractInstallArtifact.java:316)
	at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact$StateMonitorSignal.signalSuccessfulCompletion(AbstractInstallArtifact.java:252)
	at org.eclipse.virgo.kernel.core.internal.BundleStartTracker$1.run(BundleStartTracker.java:140)
	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:885)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:907)
	at java.lang.Thread.run(Thread.java:619)
SpringServletContainerInitializer is part of the org.springframework.web bundle which is available in version 3.1.2 in ext. I have no idea what might cause the problem. Same plan works fine with the original virgo (with Springframework 3.0.5)
Any hint would be appreciated.
Thorsten
Re: Problems after upgrading to Spring 3.1.2 [message #963756 is a reply to message #953608] Mon, 29 October 2012 22:39 Go to previous message
Borislav Kapukaranov is currently offline Borislav Kapukaranov
Member
Did you tried that on Virgo 3.6.0. We have successfully upgraded there to Spring 3.1 and seen this issue in the process? I think we fixed it for 3.6.0.M01.
Best Regards
Bobby
Previous Topic:can virgo runs as single region(without kernel/user isolation) mode?
Next Topic:virgo distribution without user region and with repository
Current Time: Sun May 19 16:06:45 EDT 2013
Powered by FUDForum. Page generated in 0.01523 seconds
