Home » Eclipse Projects » Virgo » can virgo runs as single region(without kernel/user isolation) mode?
can virgo runs as single region(without kernel/user isolation) mode? [message #955382] Tue, 23 October 2012 15:02 Go to next message
Yousef Fadila is currently offline Yousef Fadila
Hi All
I am interesting to run virgo without user/kernel isolation.
can this mode be configured?
Yousef
Re: can virgo runs as single region(without kernel/user isolation) mode? [message #955414 is a reply to message #955382] Tue, 23 October 2012 15:34 Go to previous messageGo to next message
Hristo Iliev is currently offline Hristo Iliev
The mode is not really configurable. Instead you can use different Virgo deliverables. In particular Virgo Nano (and Nano "Full") provides no isolation but also misses some features (PAR and repository support for example).
You can check the Feature Summary page and the short description of the Virgo deliverables for more details.
Re: can virgo runs as single region(without kernel/user isolation) mode? [message #955429 is a reply to message #955414] Tue, 23 October 2012 15:49 Go to previous messageGo to next message
Borislav Kapukaranov is currently offline Borislav Kapukaranov
Member
Just a remark - Virgo Nano Full and Virgo Nano Web are the same thing. I noticed we still use the old Nano Full name on some web pages...
Best Regards
Bobby
Re: can virgo runs as single region(without kernel/user isolation) mode? [message #955521 is a reply to message #955429] Tue, 23 October 2012 17:36 Go to previous messageGo to next message
Thanks. I will give it nano full a try.
can I still configure the tomcat in this delivery using the tomcat-server.xml? I don't see such a file in the configuration directory.
Yousef,
Re: can virgo runs as single region(without kernel/user isolation) mode? [message #963723 is a reply to message #955521] Mon, 29 October 2012 22:01 Go to previous message
Member
Yes, you can - just create a <server-root>/config directory and place your tomcat-server.xml inside. It should be automatically discovered.
Another way is to place it inside /configuration and add this property in the config.ini file:
org.eclipse.gemini.web.tomcat.config.path=configuration/tomcat-server.xml
Best Regards
Bobby
[Updated on: Mon, 29 October 2012 22:02]
Report message to a moderator
Previous Topic:Completeness of scoped plans
Next Topic:Problems after upgrading to Spring 3.1.2
Current Time: Wed May 22 22:40:07 EDT 2013
Powered by FUDForum. Page generated in 0.01677 seconds
