| Re: Updating the compiler [message #958905 is a reply to message #897058] |
Fri, 26 October 2012 06:02   |
Mickey Mouse Messages: 4 Registered: July 2012 |
Junior Member |
Hi, the issue came back. At this time I have two versions of gcc installed: 4.6.3 and 4.7.2. Globally I switched to gcc-4.7.3. However includes of the previous version of GCC are still present and Eclipse points to the old version /usr/lib64/gcc/x86_64-pc-linux-gnu/4.6.3, while it should be /usr/lib64/gcc/x86_64-pc-linux-gnu/4.7.2/. In this case the trick to clear the discovered entries does not work.
Any solution?
regards
-Mickey
[Updated on: Fri, 26 October 2012 06:03] Report message to a moderator
FUDForum. Page generated in 0.03311 seconds
