Home » Newcomers » Newcomers » EntityManagerFactory (Eclipselink RCP) return NullPointerException
icon12.gif  EntityManagerFactory (Eclipselink RCP) return NullPointerException [message #962113] Sun, 28 October 2012 18:04 Go to next message
Azi Azwady Jamaludin is currently offline Azi Azwady Jamaludin
Greetings,
I'm developing RCP application integrating Eclipselink JPA. The RCP project named as mamsys-dispose.
I've also creates a separate project for JPA and I've generates the entities using Eclipselink and convert it to Plug-in project. I also put my EntityManagerFactory and models in this project (JPA). I then put the plug-in as required plug-in at mamsys-dispose (MANIFEST-MF > Dependencies)
I'm referring to the Comics example and note that the example is old and I've made a number of configuration such as using Activator (org.eclipse.persistence.jpa.osgi) as the classloader. The emf (instance) in Comics example refers to null but in my application, emf is not referring to null (EntityManagerFactory emf;). Only at createEntityManager, I put:-
if (emf == null)
init();
But I'm still got these stack trace:-
java.version=1.6.0_35
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -application org.eclipse.mamsys-dispose.application
Command-line arguments: -application org.eclipse.mamsys-dispose.application -data /Users/azwady/eclipseRCPproj/../runtime-org.eclipse.mamsys-dispose.application -dev file:/Users/azwady/eclipseRCPproj/.metadata/.plugins/org.eclipse.pde.core/org.eclipse.mamsys-dispose.application/dev.properties -os macosx -ws cocoa -arch x86_64 -consoleLog
!ENTRY org.eclipse.core.jobs 4 2 2012-10-29 04:59:32.852
!MESSAGE An internal error occurred during: "Init View...".
!STACK 0
at org.eclipse.mamsysdispose.model.connection.MamsysEntityManagerFactory.createEntityManager(MamsysEntityManagerFactory.java:54)
at org.eclipse.mamsysdispose.model.CreateCaseModel.<init>(CreateCaseModel.java:24)
at org.eclipse.mamsysdispose.views.viewparts.NewCaseView$2$1.run(NewCaseView.java:162)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
What is missing here?.
**BTW, I'm creating this application on my Macbook and using Eclipse RCP Juno SR1.
Re: EntityManagerFactory (Eclipselink RCP) return NullPointerException [message #962510 is a reply to message #962113] Mon, 29 October 2012 01:31 Go to previous message
Ed Merks is currently offline Ed Merks
Better to ask on the EclipseLink forum:
http://www.eclipse.org/forums/eclipse.rt.eclipselink
On 29/10/2012 2:18 AM, Azi Azwady Jamaludin wrote:
> Greetings,
> Dependencies)
> if (emf == null)
> init();
> -dev
> !STACK 0
> java.lang.NullPointerException
> at
> at
> at
> What is missing here?. **BTW, I'm creating this application on my
Previous Topic:Where to go to contribute to Eclipse?
Next Topic:Eclipse Juno (4.2.1) and RedHat 5.8 64bit
Current Time: Tue May 21 03:49:33 EDT 2013
Powered by FUDForum. Page generated in 0.01822 seconds
