Home » Modeling » TMF (Xtext) » How to execute two different types of resolution in same unit of work?
How to execute two different types of resolution in same unit of work? [message #959108] Fri, 26 October 2012 09:06 Go to next message
Cristiano Gaviao is currently offline Cristiano Gaviao
I'm trying to create a quickfix that does two different types of changes in same unit of work. One is based in semantic and the other based in the offset.
I follow the DefaultQuickfixProvider's createLinkingIssueResolutions method, but using a xtextDocument.modify(new IUnitOfWork.Void<XtextResource>() instead.
I tried something like the code below. I use the ISemanticModification to add the offset change :
public void createQualifiedNameIssueResolutions(final Issue issue,
			final IssueResolutionAcceptor issueResolutionAcceptor) {
final IModificationContext modificationContext = getModificationContextFactory()
				.createModificationContext(issue);
final IXtextDocument xtextDocument = modificationContext
				.getXtextDocument();
	if (xtextDocument == null)
			return;
	xtextDocument.modify(new IUnitOfWork.Void<XtextResource>() {
	public void process(XtextResource state) throws Exception {
		EObject target = state.getEObject(issue.getUriToProblem()
						.fragment());
		EReference reference = getUnresolvedEReference(issue, target);
		if (reference == null)
					return;
		String issueString = xtextDocument.get(issue.getOffset(),
						issue.getLength());
		String simpleName = getQualifiedNameConverter()
						.toQualifiedName(issueString).getLastSegment()
						.toString();
		createImportResolution(target, issueString, issue,
						issueResolutionAcceptor, issueString, simpleName);
protected void createImportResolution(final EObject target,
			final String issueString, final Issue issue,
			final IssueResolutionAcceptor issueResolutionAcceptor,
			final String importText, final String simpleName) {
issueResolutionAcceptor.accept(issue, label, description,
				null, new ISemanticModification() {
public void apply(EObject element,IModificationContext context) throws Exception {
IXtextDocument xtextDocument = context.getXtextDocument();
xtextDocument.replace(issue.getOffset(),issue.getLength(), simpleName);
ComponentTemplateLibrary library = EcoreUtil2.getContainerOfType(
element, ComponentTemplateLibrary.class);
Import importobj = ComponentTemplateLibraryDslFactory.eINSTANCE.createImport();
IJvmTypeProvider typeProvider = typeProviderFactory.findOrCreateTypeProvider(library.eResource().getResourceSet());
JvmType jvmType = typeProvider.findTypeByName(importText);			importobj.setImportedType(jvmType);						library.getImports().add(importobj);
With the two change I'm getting the error below. When I comment one of the two changes, the execution for both is normal.
!STACK 0
org.eclipse.emf.common.util.WrappedException: java.lang.RuntimeException: org.eclipse.text.edits.MalformedTreeException: End position lies outside document range
	at org.eclipse.xtext.ui.editor.quickfix.IssueResolution.apply(IssueResolution.java:82)
	at org.eclipse.xtext.ui.editor.quickfix.QuickAssistCompletionProposal.apply(QuickAssistCompletionProposal.java:32)
	at org.eclipse.xtext.ui.editor.hover.AnnotationWithQuickFixesHover$AnnotationInformationControl.apply(AnnotationWithQuickFixesHover.java:525)
	at org.eclipse.xtext.ui.editor.hover.AnnotationWithQuickFixesHover$AnnotationInformationControl.access$2(AnnotationWithQuickFixesHover.java:502)
	at org.eclipse.xtext.ui.editor.hover.AnnotationWithQuickFixesHover$AnnotationInformationControl$5.widgetSelected(AnnotationWithQuickFixesHover.java:496)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4134)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1458)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1481)
	at org.eclipse.swt.widgets.Widget.sendSelectionEvent(Widget.java:1531)
	at org.eclipse.swt.widgets.Link.textView_clickOnLink_atIndex(Link.java:117)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:5807)
	at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native Method)
	at org.eclipse.swt.widgets.Widget.callSuper(Widget.java:221)
	at org.eclipse.swt.widgets.Widget.mouseDownSuper(Widget.java:1093)
	at org.eclipse.swt.widgets.Widget.mouseDown(Widget.java:1085)
	at org.eclipse.swt.widgets.Control.mouseDown(Control.java:2538)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:5493)
	at org.eclipse.swt.widgets.Widget.windowSendEvent(Widget.java:2102)
	at org.eclipse.swt.widgets.Shell.windowSendEvent(Shell.java:2299)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:5557)
	at org.eclipse.swt.widgets.Display.applicationSendEvent(Display.java:5002)
	at org.eclipse.swt.widgets.Display.applicationProc(Display.java:5151)
	at org.eclipse.swt.internal.cocoa.OS.objc_msgSend(Native Method)
	at org.eclipse.swt.internal.cocoa.NSApplication.sendEvent(NSApplication.java:128)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3616)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1029)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.RuntimeException: org.eclipse.text.edits.MalformedTreeException: End position lies outside document range
	at org.eclipse.xtext.ui.editor.model.edit.ReconcilingUnitOfWork.exec(ReconcilingUnitOfWork.java:46)
	at org.eclipse.xtext.ui.editor.model.edit.ReconcilingUnitOfWork.exec(ReconcilingUnitOfWork.java:1)
	at org.eclipse.xtext.util.concurrent.AbstractReadWriteAcces.modify(AbstractReadWriteAcces.java:49)
	at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.modify(XtextDocument.java:181)
	at org.eclipse.xtext.ui.editor.model.XtextDocument.internalModify(XtextDocument.java:90)
	at org.eclipse.xtext.ui.editor.model.XtextDocument.modify(XtextDocument.java:83)
	at org.eclipse.xtext.ui.editor.model.edit.SemanticModificationWrapper.apply(SemanticModificationWrapper.java:31)
	at org.eclipse.xtext.ui.editor.quickfix.IssueResolution.apply(IssueResolution.java:80)
	... 51 more
Caused by: org.eclipse.text.edits.MalformedTreeException: End position lies outside document range
	at org.eclipse.text.edits.TextEditProcessor.checkIntegrityDo(TextEditProcessor.java:178)
	at org.eclipse.text.edits.TextEdit.dispatchCheckIntegrity(TextEdit.java:743)
	at org.eclipse.text.edits.TextEditProcessor.performEdits(TextEditProcessor.java:151)
	at org.eclipse.text.edits.TextEdit.apply(TextEdit.java:711)
	at org.eclipse.text.edits.TextEdit.apply(TextEdit.java:735)
	at org.eclipse.xtext.ui.editor.model.edit.ReconcilingUnitOfWork.exec(ReconcilingUnitOfWork.java:42)
	... 58 more
Could someone point me how could I accomplish this?
thanks
Cristiano
Re: How to execute two different types of resolution in same unit of work? [message #960505 is a reply to message #959108] Sat, 27 October 2012 10:47 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian Zarnekow
Cristiano,
that's not possible. You have to perform the complete changes in one and
the same way, e.g. everything based on the text or everything based on
the semantic model. Otherwise the produced text edits will not be in sync.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 26.10.12 15:06, schrieb Cristiano Gaviao:
> the offset.
> IUnitOfWork.Void<XtextResource>() instead. I tried something like the
> return;
> @Override
> .fragment());
> return;
> issue.getLength());
> .toString();
> Exception {
> Import importobj =
> !STACK 0
> document range
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> document range
> at
> at
> at
> at
> at
> at
> at
> at
> ... 51 more
> at
> at
> at
> at
> ... 58 more
> thanks
> Cristiano
Re: How to execute two different types of resolution in same unit of work? [message #960638 is a reply to message #960505] Sat, 27 October 2012 13:15 Go to previous message
Hey Sebastian,
I would like to change the qualified name by a simple name and same time insert an import statement. Could you suggest me a way to do that using one of the two approaches?
thanks a lot,
Cristiano
Previous Topic:testing autocompletion (and other UI stuff)
Next Topic:Packages should be imported by their namespace URI.
Current Time: Thu May 23 13:43:45 EDT 2013
Powered by FUDForum. Page generated in 0.09972 seconds
