Home » Modeling » XSD » XSD with IDREF -> ecore(missing type of IDREF)
icon5.gif  XSD with IDREF -> ecore [message #756552] Mon, 14 November 2011 04:46 Go to next message
Frank Missing name is currently offline Frank Missing name
I'm generating my ecore model from a schema file. It works fine, except one thing: I'm using some IDREF stuff in the schema and in the ecore model I don't get the expected type, although I have provided the intended type by using the
ecore:reference="my ref type..."
attribute. The reference in the ecore model is always of type EObject.
Yes, I can change that after loading the XSD file, and than it works fine, but I don't want to change the ecore model once loaded from the XSD.
Any idea what's going wrong there?
Thanks in advance
Frank
Re: XSD with IDREF -> ecore [message #959061 is a reply to message #756552] Fri, 26 October 2012 08:27 Go to previous message
Jeff MAURY is currently offline Jeff MAURY
I had the same problem but I added the tns: prefix before the type name and everything worked after
Previous Topic:xsd enumeration value containing colon is not getting validated!
Next Topic:The location has not been resolved because the import is unused
Current Time: Tue May 28 18:28:09 EDT 2013
Powered by FUDForum. Page generated in 0.01522 seconds
