| Eclipse compilation without packages and project creation [message #957867] |
Thu, 25 October 2012 11:03  |
geek bits Messages: 1 Registered: October 2012 |
Junior Member |
Hi all !
This is my first post @ Eclipse and I am new to Eclipse. I am a beginner in Java. I had been using Edit Plus . I create .java files in Edit Plus and compile and run in the command prompt. I find this very convenient.
Though the same can be done in Eclipse too, but by default, I need to create a New Project and then Package and Class file and then creating .java files. Compiling and running can be done in Eclipse itself or in the command prompt.
I do not need project and packages as of now as I am beginner , I am trying to get comfortable in java by trying with lot of basic programs in java for which packages and projects not needed.
My question is : Can we create .java files without creating project and packages ( as I used to do in Edit Plus ) and save it and compile it in command prompt ?
Thanks & Regards
Geek Bits
FUDForum. Page generated in 0.08509 seconds
