| Re: [buckminster-dev] headless resolve with properties [message #9575] |
Thu, 13 March 2008 16:35 |
Todd Lee Messages: 44 Registered: July 2009 |
Member |
Thanks a bunch Adrian!
Much appreciated - I'll give it a try.
Cheers
T
"Adrian Skehill"
<adrian.skehill@g
mail.com> To
Sent by: "Buckminster developer discussions"
buckminster-dev-b <buckminster-dev@eclipse.org>
ounces@eclipse.or cc
g
Subject
03/13/2008 04:29 resolve with properties
PM
Please respond to
Buckminster
developer
discussions
<buckminster-dev@
eclipse.org>
> Hey Adrian,
> Thanks again for the tip. I have a couple of questions I'm wondering if
you
> can clarify on importing from a local SDK:
> - what ReaderType do you use for the provider, is it eclipse.import or
> eclipse.platform?
> - did you actually create a local update site (I was under the
impression
> that eclipse.import was used pretty much exclusively with update
sites...)
> or are you just pointing it to a directory with an extracted Eclipse
> SDK.zip?
> If it's not asking too much, perhaps I'd be able to get a better handle
on
> this if you could provide a sample snippet from your RMAP/setup?
Hi Todd,
I was working with a colleague of mine today at work with the Eclipse
STP project and getting the buckminster builds sorted out there, so
I'm able to easily show you those rmap and cquery files if you want to
test it out, it's available at [1]. The stuff I'm involved isn't so
easy to share since it's behind our corporate firewall.
Take a look at the Ganymede section, you'll get all the info you need
there, we assume there's an eclipse installed in /shared/... with all
the plugins we need. The plugins your build needs are then imported
into the workspace.
Hope this helps,
Adrian.
[1] http://dev.eclipse.org/svnroot/stp/build/trunk/buckminster/s tp.rmap
_______________________________________________
buckminster-dev mailing list
https://dev.eclipse.org/mailman/listinfo/buckminster-dev
AMI Semiconductor - "Silicon Solutions for the Real World"
NOTICE:
This electronic message contains information that may be confidential or privileged. The information is intended for the use of the individual or entity named above. If you are not the intended recipient, please be aware that any disclosure, copying, distribution or use of the contents of this information is prohibited. If you received this electronic message in error, please notify the sender and delete the copy you received.
FUDForum. Page generated in 0.01548 seconds
