Home » Eclipse Projects » Eclipse 4 » No application icon on main windows(Set an icon for a trimmed window)
No application icon on main windows [message #956782] Wed, 24 October 2012 16:05 Go to next message
Jim Jones is currently offline Jim Jones
I was trying to set an IconURI for a Trimmed Window in my application's Application.e4xmi but it does not work.
It seems that this is a bug (https://bugs.eclipse.org/bugs/show_bug.cgi?id=332823) but from the notes in the chain in this link it seems that there is some kind of work arround for this.
Well is there a workarround for this?
[Updated on: Wed, 24 October 2012 16:06]
Report message to a moderator
Re: No application icon on main windows [message #957513 is a reply to message #956782] Thu, 25 October 2012 05:24 Go to previous messageGo to next message
Christoph Keimel is currently offline Christoph Keimel
Could this be a duplicate of https://bugs.eclipse.org/bugs/show_bug.cgi?id=280825?
If yes, Eric fixed it in the 4.2 maintenance stream.
[Updated on: Thu, 25 October 2012 05:24]
Re: No application icon on main windows [message #957553 is a reply to message #956782] Thu, 25 October 2012 05:59 Go to previous messageGo to next message
Lars Vogel is currently offline Lars Vogel
Yes, should be fixed. @Jim, please re-test in the latest integration build.
You find info how to get the latest integration build here: Eclipse 4 Source.
Re: No application icon on main windows [message #958167 is a reply to message #957553] Thu, 25 October 2012 16:19 Go to previous messageGo to next message
I installed E4 UI update from http://download.eclipse.org/e4/updates/0.12-I-builds/ like in the link suggested but it did not solve the problem.
Should I have updated something else?
index.php/fa/12078/0/
Re: No application icon on main windows [message #958214 is a reply to message #958167] Thu, 25 October 2012 17:14 Go to previous messageGo to next message
These are just the e4 tools, e.g. the application model editor. This bug solved a runtime issue, you need to download the full Eclipse 4 integration build.
Re: No application icon on main windows [message #959499 is a reply to message #958214] Fri, 26 October 2012 15:23 Go to previous messageGo to next message
Hi Lars Vogel,
I don't understand what I am supposed to do and what you mean.
Should I choose all the checkboxes in the above image I posted?
In this link http://download.eclipse.org/eclipse/downloads/I see mention about 4.3 Integration Build but not about 4.2.
Could you please explain a little. I am newbie, so I am sorry if my question is too trivial for you.
Thank you for your time!
[Updated on: Fri, 26 October 2012 15:24]
Re: No application icon on main windows [message #960306 is a reply to message #958214] Sat, 27 October 2012 07:02 Go to previous messageGo to next message
Jim Jone is currently offline Jim Jone
I installed everything in the above image.No success.What am I supposed to install?
I don't understand
Re: No application icon on main windows [message #960619 is a reply to message #960306] Sat, 27 October 2012 12:55 Go to previous messageGo to next message
Brian de Alwis is currently offline Brian de Alwis
See the link for the Eclipse 4.2 Maintenance Build.
Re: No application icon on main windows [message #961643 is a reply to message #960619] Sun, 28 October 2012 09:08 Go to previous messageGo to next message
@Brian de Alwis:
All the status icons are red for Eclipse 4.2 Maintainance Build.
Does this mean that there is issue with this release?
index.php/fa/12108/0/
[Updated on: Sun, 28 October 2012 09:09]
Re: No application icon on main windows [message #962094 is a reply to message #961643] Sun, 28 October 2012 17:42 Go to previous messageGo to next message
Sopot Cela is currently offline Sopot Cela
No it should work. Download and try it.
Re: No application icon on main windows [message #963428 is a reply to message #956782] Mon, 29 October 2012 16:20 Go to previous messageGo to next message
I updated my Eclipse 4 Source description. See Point 1.2 Eclipse 4 Download.
Re: No application icon on main windows [message #967298 is a reply to message #963428] Thu, 01 November 2012 13:03 Go to previous messageGo to next message
@Lars Vogel:
So I am not recommended to somehow "upgrade" 4.2?
But install fresh 4.3 for this issue?Is this what you mean?
Re: No application icon on main windows [message #967338 is a reply to message #967298] Thu, 01 November 2012 13:39 Go to previous message
@Jim, yes please try the latest Eclipse 4.3 Integration build as I said in my very first answer. Eclipse 4.2 is finished so there are no integration builds for it anymore.
Previous Topic:IllegalStateException on accessing EPartService
Next Topic:Force.com IDE password issue
Current Time: Sat May 25 11:29:09 EDT 2013
Powered by FUDForum. Page generated in 0.12679 seconds
