Home » Eclipse Projects » EGit » Pushing, auth fail(Suddenly can't push to github)
Pushing, auth fail [message #955892] Wed, 24 October 2012 00:49 Go to next message
Davis Mariotti is currently offline Davis Mariotti
Very suddenly, I can no longer push my files over to github, doing the same exact steps as I had previously done, but now I get a message saying auth fail. wWhat should I do?
Re: Pushing, auth fail [message #964206 is a reply to message #955892] Tue, 30 October 2012 06:40 Go to previous messageGo to next message
Matthew Webber is currently offline Matthew Webber
Can you tell us what you are doing in a bit more detail? Does this fail for all repositories, or only some? You have checked that you are (still) authorized, I presume?
Are you using the same machine that you previously used? Is your ssh key for GiHub there?
Try it from the command line, and see if it works there.
Re: Pushing, auth fail [message #967631 is a reply to message #955892] Thu, 01 November 2012 18:37 Go to previous messageGo to next message
Robin Rosenberg is currently offline Robin Rosenberg
Davis Mariotti skrev 2012-10-24 10.37:
Assuming SSH: Check that Eclipse looks for SSH keys in the right location.
-- robin
Re: Pushing, auth fail [message #968882 is a reply to message #967631] Fri, 02 November 2012 16:49 Go to previous messageGo to next message
How do I do that?
Re: Pushing, auth fail [message #974176 is a reply to message #968882] Tue, 06 November 2012 17:56 Go to previous message
Matthias Sohn is currently offline Matthias Sohn
See http://wiki.eclipse.org/EGit/User_Guide#Eclipse_SSH_Configuration
Previous Topic:EGit imported repositories are not connected to Git once added
Next Topic:Merge tool - repository merge view shows non-conflicting files
Current Time: Sat May 25 03:08:02 EDT 2013
Powered by FUDForum. Page generated in 0.01970 seconds
