Home » Newcomers » Newcomers » Failed to install Package of "Eclipse IDE for C/C++ Developers"(on XP windows)
Failed to install Package of "Eclipse IDE for C/C++ Developers" [message #955327] Tue, 23 October 2012 14:01 Go to next message
Albert Cheng is currently offline Albert Cheng
I downloaded the 32 bit Juno package of "Eclipse IDE for C/C++ Developers", unzipped it and tried to install it, but, got error message as " Failed to create the Java Virtual Machine".
After read the readme file came with the package, understoond the package was tested with Java of "Oracle Java 7 Update 2 ". then, donwloaded 'Oracle Java 7 Update 2 " from Orcal website and installed it.
Re-install the Juno package of "Eclipse IDE for C/C++ Developers" again, still got the same error.
Anyone help me out here?
Albert
Re: Failed to install Package of "Eclipse IDE for C/C++ Developers" [message #955471 is a reply to message #955327] Tue, 23 October 2012 16:37 Go to previous messageGo to next message
David Wegener is currently offline David Wegener
Take a look at the FAQ:
http://wiki.eclipse.org/FAQ_How_do_I_run_Eclipse%3F
http://wiki.eclipse.org/Eclipse.ini
Re: Failed to install Package of "Eclipse IDE for C/C++ Developers" [message #956540 is a reply to message #955471] Wed, 24 October 2012 11:44 Go to previous message
I figured out the issue, let me share with you guys.
The issue was how to download the Juno package from the website of eclipse.org. we need to download working package from below link ( today is Oct.24,2012)
http://www.eclipse.org/downloads/download.php?file=/technology/epp/downloads/release/juno/R/eclipse-cpp-juno-win32.zip
the package of eclipse-cpp-juno-win32.zip works well with "Oracle Java 7 Update 2"
Above 2 packages somehow doesn't work with "Oracle Java 7 Update 2 ".
Do not downlaod packages from below links:
http://www.eclipse.org/downloads/download.php?file=/technology/epp/downloads/release/juno/SR1/eclipse-cpp-juno-SR1-win32.zip
or
http://download.eclipse.org/eclipse/downloads/drops4/R-4.2.1-201209141800/
Previous Topic:problem installing the 64 bit (3.6.1)
Next Topic:Ant build.xml not using correct properties file
Current Time: Fri May 24 16:05:44 EDT 2013
Powered by FUDForum. Page generated in 0.01871 seconds
