Home » Eclipse Projects » EclipseLink » ValidationException for enum class
ValidationException for enum class [message #954994] Tue, 23 October 2012 08:16 Go to next message
Sebastian Lorenz is currently offline Sebastian Lorenz
I'm getting the following exception:
Caused by: Exception [EclipseLink-7151] (Eclipse Persistence Services - 2.4.1.v20121003-ad44345): org.eclipse.persistence.exceptions.ValidationException
Exception Description: The type [class commons.Gender] for the attribute [gender] on the entity class [class persistence.PatientEntity] is not a valid type for an enumerated mapping. The attribute must be defined as a Java enum.
But I can't figure out why since I assume my classes to be O.K.:
public class PatientEntity implements Lockable<Long>, Identifiable<Long> {
  private Gender gender;
  @Enumerated(EnumType.STRING)
  @Column(name = "gender")
  public Gender getGender() {
    return this.gender;
  public void setGender(Gender gender) {
    this.gender = gender;
public enum Gender implements ExtendedDisplayable {
	NONE,
	MALE,
	FEMALE;
Btw. The excpetion appears at application startup. But the application is running without any problems. I can inssert and select patients from the database.
[Updated on: Tue, 23 October 2012 09:41]
Report message to a moderator
Re: ValidationException for enum class [message #964676 is a reply to message #954994] Tue, 30 October 2012 14:07 Go to previous messageGo to next message
James Sutherland is currently offline James Sutherland
What environment are you running in? Can you include the full exception stack.
It could be some sort of class loader issues. If things are working, you may be able to just ignore the issue.
James : Wiki : Book : Blog
Re: ValidationException for enum class [message #975026 is a reply to message #964676] Wed, 07 November 2012 09:38 Go to previous message
I'm using Gemini JPA and -Blueprint. I think you are right and this has smth. to do with classloading in this environement. Thanks.
Previous Topic:TopLink to EclipseLink migration
Next Topic:@StoredProcedureParameter direction is deprecated
Current Time: Wed May 22 12:45:49 EDT 2013
Powered by FUDForum. Page generated in 0.01618 seconds
