Home » Eclipse Projects » Eclipse 4 » Contacts Demo not working properly(Contacts demo)
Contacts Demo not working properly [message #954788] Tue, 23 October 2012 08:48 Go to next message
Nagesh Bansal is currently offline Nagesh BansalFriend
Please look at the attached files and the error trace and tell me why the contacts demo is not working properly. Secondly using the vogella tutorial i am unable to create a editor in eclipse 4. Do you have nay other suggestion. By editor I mean a proper java like editor that we have in eclipse for my RCP app.
index.php/fa/12014/0/
  • Attachment: contacts.png
    (Size: 85.69KB, Downloaded 486 times)
  • Attachment: contacts.txt
    (Size: 34.43KB, Downloaded 347 times)
[Updated on: Tue, 23 October 2012 08:49]
Report message to a moderator
Re: Contacts Demo not working properly [message #955702 is a reply to message #954788] Wed, 24 October 2012 01:08 Go to previous messageGo to next message
Brian de Alwis is currently offline Brian de AlwisFriend
Given the warnings, I think you're using an out-of-date version of the Contacts demo. One notable change is the requirement to use @Creatable to allow unto creation of objects during injection, such as DetailsComposite.
Brian.
Eclipse Platform committer. Ask me about Eclipse support, training, and consulting.
Re: Contacts Demo not working properly [message #962893 is a reply to message #955702] Mon, 29 October 2012 12:07 Go to previous messageGo to next message
I tried with the latest and still am facing the same issue!
However in this case the error now is
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-29 17:36:48.528
!MESSAGE Unable to create class 'org.eclipse.e4.demo.contacts.views.DetailsView' from bundle '80'
!STACK 0
org.eclipse.e4.core.di.InjectionException: Unable to process "DetailsView.detailComposite": no actual value was found for the argument "DetailComposite".
at org.eclipse.e4.core.internal.di.InjectorImpl.reportUnresolvedArgument(InjectorImpl.java:394)
at org.eclipse.e4.core.internal.di.InjectorImpl.resolveRequestorArgs(InjectorImpl.java:385)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:100)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:319)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:240)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:141)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:896)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:630)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:732)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:703)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:697)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:682)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1114)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:67)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4687)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:187)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:103)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:646)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:59)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:642)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:639)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:964)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:150)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Re: Contacts Demo not working properly [message #988826 is a reply to message #962893] Mon, 03 December 2012 11:06 Go to previous messageGo to next message
Sorry to bump this post, but it would be really helpful if someone could address this...
Re: Contacts Demo not working properly [message #988827 is a reply to message #988826] Mon, 03 December 2012 11:08 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
so where from did you check it out? Which repository?
Tom
Am 03.12.12 12:06, schrieb Nagesh Bansal:
> address this...
Re: Contacts Demo not working properly [message #988833 is a reply to message #988827] Mon, 03 December 2012 11:39 Go to previous messageGo to next message
Initially I had downloaded it from CVS repository from org.eclipse.e4.ui.releng.
Then I searched and downloaded it from org.eclipse.e4.ui
Re: Contacts Demo not working properly [message #988839 is a reply to message #988833] Mon, 03 December 2012 12:07 Go to previous message
You need to get it from the git-repo at
http://git.eclipse.org/c/platform/eclipse.platform.ui.git where it is at
http://git.eclipse.org/c/platform/eclipse.platform.ui.git/tree/examples/org.eclipse.e4.demo.contacts
Tom
Am 03.12.12 12:39, schrieb Nagesh Bansal:
Previous Topic:How to force the creation of instance of Part class URI?
Next Topic:Manually triggering a class with injections?
Current Time: Sat Jul 22 08:48:37 GMT 2017
Powered by FUDForum. Page generated in 0.03358 seconds
