Home » Modeling » UML2 Tools » Install Error - UML Designer BeoNetwords in Indigo(Can't Install UML Designer in Indigo - Errors)
Install Error - UML Designer BeoNetwords in Indigo [message #953845] Mon, 22 October 2012 11:27 Go to next message
Alex Kerezy is currently offline Alex Kerezy
I am new to the eclipse framework/platform and .....well..... I can't say I have much good to say about my experiences.
I want to create a component model and corresponding class diagrams. I installed Version: Indigo Service Release 2 Build id: 20120216-1857 - currently installed.
I am trying to install the UML Designer (Indigo version) 1.4 and I get a bunch of errors shown below.
Any Help Would be GREATLY Appreciated!!
Alex
Cannot complete the install because of a conflicting dependency.
Software being installed: UML Designer (based on Obeo Designer) 1.4.0.201208281448 (org.obeonetwork.dsl.feature.uml2.feature.group 1.4.0.201208281448)
Software currently installed: Eclipse Modeling Tools 1.4.2.20120213-0813 (epp.package.modeling 1.4.2.20120213-0813)
Only one of the following can be installed at once:
Acceleo Ecore Module Runtime Plug-in 1.1.1.201206051542 (org.eclipse.emf.eef.codegen.ecore 1.1.1.201206051542)
Acceleo Ecore Module Runtime Plug-in 1.0.0.v20110608-0819 (org.eclipse.emf.eef.codegen.ecore 1.0.0.v20110608-0819)
Acceleo Ecore Module Runtime Plug-in 1.0.1.v20110912-0930 (org.eclipse.emf.eef.codegen.ecore 1.0.1.v20110912-0930)
Acceleo Ecore Module Runtime Plug-in 1.0.2.v20120216-1513 (org.eclipse.emf.eef.codegen.ecore 1.0.2.v20120216-1513)
Cannot satisfy dependency:
From: Eclipse Modeling Tools 1.4.2.20120213-0813 (epp.package.modeling 1.4.2.20120213-0813)
To: org.eclipse.epp.package.modeling.feature.feature.group [1.4.2.20120213-0813]
From: Obeo Designer 6.0.2.201208210959 (fr.obeo.dsl.feature.designer.architect.feature.group 6.0.2.201208210959)
To: org.eclipse.emf.eef.sdk-feature.feature.group [1.1.0,2.0.0)
From: Extended Editing Framework - EMF Edit generation using Acceleo 1.1.1.201206051542 (org.eclipse.emf.eef.codegen.ecore-feature.feature.group 1.1.1.201206051542)
To: org.eclipse.emf.eef.codegen.ecore [1.1.1.201206051542]
From: Extended Editing Framework - EMF Edit generation using Acceleo 1.0.0.v20110608-0819 (org.eclipse.emf.eef.codegen.ecore.feature.group 1.0.0.v20110608-0819)
To: org.eclipse.emf.eef.codegen.ecore [1.0.0.v20110608-0819]
From: Extended Editing Framework - EMF Edit generation using Acceleo 1.0.1.v20110912-0930 (org.eclipse.emf.eef.codegen.ecore.feature.group 1.0.1.v20110912-0930)
To: org.eclipse.emf.eef.codegen.ecore [1.0.1.v20110912-0930]
From: Extended Editing Framework - EMF Edit generation using Acceleo 1.0.2.v20120216-1513 (org.eclipse.emf.eef.codegen.ecore.feature.group 1.0.2.v20120216-1513)
To: org.eclipse.emf.eef.codegen.ecore [1.0.2.v20120216-1513]
From: Extended Editing Framework - SDK 1.1.1.201206051542 (org.eclipse.emf.eef.sdk-feature.feature.group 1.1.1.201206051542)
To: org.eclipse.emf.eef.codegen.ecore-feature.feature.group [1.1.1.201206051542]
From: EPP Modeling Feature 1.4.2.20120213-0813 (org.eclipse.epp.package.modeling.feature.feature.group 1.4.2.20120213-0813)
To: org.eclipse.emf.eef.codegen.ecore.feature.group 0.0.0
From: UML Designer (based on Obeo Designer) 1.4.0.201208281448 (org.obeonetwork.dsl.feature.uml2.feature.group 1.4.0.201208281448)
To: fr.obeo.dsl.feature.designer.architect.feature.group 6.0.0
Re: Install Error - UML Designer BeoNetwords in Indigo [message #953950 is a reply to message #953845] Mon, 22 October 2012 13:09 Go to previous messageGo to next message
You are using a proprietary product based upon Eclipse. The problems are
clearly associated with that product. Please consult the vendor.
Ed Willink
On 22/10/2012 17:47, Alex Kerezy wrote:
> Alex
> 1.4.0.201208281448)
> Only one of the following can be installed at once: Acceleo Ecore
> 1.1.1.201206051542)
Re: Install Error - UML Designer BeoNetwords in Indigo [message #954197 is a reply to message #953950] Mon, 22 October 2012 17:29 Go to previous messageGo to next message
Thanks for the reply,
Uhhhh..... is there an Eclipse 'preferred'/'approved' or 'native' UML modeling plugin or product?
Alex
Re: Install Error - UML Designer BeoNetwords in Indigo [message #954732 is a reply to message #954197] Tue, 23 October 2012 03:47 Go to previous message
Peter  is currently offline Peter
Member
Have a look at http://www.eclipse.org/modeling/mdt/papyrus/
Am 22.10.2012 23:29, schrieb Alex Kerezy:
> Thanks
> Alex
Previous Topic:Please help ( deployment diagram)
Next Topic:How to visualize graphically .UML file
Current Time: Tue May 28 18:01:33 EDT 2013
Powered by FUDForum. Page generated in 0.10371 seconds
