| kdm to uml (still) fails [message #953771] |
Mon, 22 October 2012 10:19  |
moritz du Messages: 98 Registered: February 2010 |
Member |
some month ago i tried modisco the first time an stumbled across a bug
this bug i reproduced with indigo and modisco 9.2
now i am on juno and modisco 10.1 but i still can't create uml model from kdm but the error message has changed:
message:
Cannot set feature uml!Class.ownedTemplateSignature to value org.eclipse.uml2.uml.internal.impl.RedefinableTemplateSignatureImpl@320dcb16 (name: <unset>, visibility: <unset>) (isLeaf: false) (org.eclipse.modisco.kdm.uml2converter_0.10.1.v201209190814)
trace:
org.eclipse.m2m.atl.engine.vm.VMException: Cannot set feature uml!Class.ownedTemplateSignature to value org.eclipse.uml2.uml.internal.impl.RedefinableTemplateSignatureImpl@320dcb16 (name: <unset>, visibility: <unset>) (isLeaf: false)
at A.__applyTemplateUnitToClass(1 : NTransientLink;) : ??#163(KDMtoUML.atl[473:3-473:38])
local variables = {tgt=umlOutput!ArrayList, src=kdmInput!ArrayList<E>, link=TransientLink {rule = 'TemplateUnitToClass', sourceElements = {src = kdmInput!ArrayList<E>}, targetElements = {tgt = umlOutput!ArrayList, signature = umlOutput!<notnamedyet>}, variables = {realType = kdmInput!ArrayList}}, self=KDMtoUML : ASMModule, null=kdmInput!ArrayList, realType=kdmInput!ArrayList, signature=umlOutput!<notnamedyet>}
local stack = [umlOutput!ArrayList]
Java Stack:
at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.set(ASMEMFModelElement.java:513)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:323)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation.java:173)
at org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASMOclAny.java:130)
at org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASMOclAny.java:78)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:251)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:357)
at org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:346)
at org.eclipse.m2m.atl.engine.vm.AtlLauncher.launch(AtlLauncher.java:216)
at org.eclipse.m2m.atl.engine.vm.AtlLauncher.launch(AtlLauncher.java:127)
at org.eclipse.m2m.atl.engine.vm.AtlLauncher.launch(AtlLauncher.java:92)
at org.eclipse.modisco.util.atl.core.internal.AtlLaunchHelper.runTransformation(AtlLaunchHelper.java:194)
at org.eclipse.modisco.util.atl.core.internal.AtlLaunchHelper.runTransformation(AtlLaunchHelper.java:173)
at org.eclipse.modisco.kdm.uml2converter.internal.KdmToUmlConverter.getUML2ModelFromKDMModelWithCustomTransformation(KdmToUmlConverter.java:114)
at org.eclipse.modisco.kdm.uml2converter.internal.KdmToUmlConverter.getUML2ModelFromKDMModel(KdmToUmlConverter.java:79)
at org.eclipse.modisco.kdm.uml2converter.DiscoverUmlModelFromKdmModel.basicDiscoverElement(DiscoverUmlModelFromKdmModel.java:89)
at org.eclipse.modisco.kdm.uml2converter.DiscoverUmlModelFromKdmModel.basicDiscoverElement(DiscoverUmlModelFromKdmModel.java:1)
at org.eclipse.modisco.infra.discovery.core.AbstractDiscoverer.discoverElement(AbstractDiscoverer.java:93)
at org.eclipse.modisco.infra.discovery.core.AbstractModelDiscoverer.discoverElement(AbstractModelDiscoverer.java:183)
at org.eclipse.modisco.infra.discovery.ui.internal.actions.MoDiscoMenuSelectionListener.discovererElement(MoDiscoMenuSelectionListener.java:229)
at org.eclipse.modisco.infra.discovery.ui.internal.actions.MoDiscoMenuSelectionListener$1.run(MoDiscoMenuSelectionListener.java:168)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Caused by: java.lang.NullPointerException
session data:
eclipse.buildId=M20120914-1800
java.version=1.7.0_03
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product
This is a continuation of log file C:\Users\stl1335\workspace-indigo\.metadata\.bak_1.log
Created Time: 2012-10-22 15:26:49.559
i tried kdm->uml with different projects (from simple with 3 classes to very complex ones), the error occurs directly after pressing ok.
so is there a way to get an uml model from a java project?
| Re: kdm to uml (still) fails [message #953911 is a reply to message #953771] |
Mon, 22 October 2012 12:29   |
Hugo Bruneliere Messages: 470 Registered: July 2009 |
The MoDisco team has still not been able to work on this particular issue.
Please, could you update anyway the corresponding bug by adding your new error trace?
Thanks again for your valuable feedback.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
FUDForum. Page generated in 0.01538 seconds
